I just need advice, i went high mount turbo setup with tial 38mm external wastegate and because i cant use stock blow off i need suggestions of which blow off sounds nice on a skyline...i got old style blitz bov on my old stock intercooler pipes but im not sure if thats gonna leak at 15psi and what sound it makes, i got option of new r2d2 sard bov, but not sure how that one sounds...which bov u got on your skyline and can u give me some opinions of which sound good to u?
https://www.sau.com.au/forums/topic/90256-bov-choice/
http://www.935motorsports.com/bovmediaX.htm
i had a look at this site and i prefer most sound of Greddy type s bov, click on file Greddy Type S on 7MGTE Supra / TO4E / Hardpipes, and ull know what i mean
Anyone got sard r2d2 on thir skyline as ill prolly go for this one...
https://www.sau.com.au/forums/topic/90256-bov-choice/#findComment-1628408
anyone have sard r2d2, how does it sound on a skyline, which bov sounds as on a clip above, they say its greddy type s but i never heard greddy sound like that?
https://www.sau.com.au/forums/topic/90256-bov-choice/#findComment-1629039
do i need bov at all as i have external wastegate, is no bov gonna hurt the turbo?
The topic has been done to death one example is here - http://www.skylinesaustralia.com/forums/in...showtopic=78398
A bov will kill throttle response, as it allows all the pressurised air to escape you intercooler/pipework as soon as you lift off even slightly
https://www.sau.com.au/forums/topic/90256-bov-choice/#findComment-1629702
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
