  • Replies 80
haha yeah mate
decided to give her a wash on the weekend and took some nice shots on the nice n green grass :D (since i received my new digi camera :D )
i dont think dad was too happy when i spun the tyrs on it though, my tyres r bald as a shaven ***** :lol:
AA is like realistic...you have to train n shit to progress if i remember correctly....
its army based, not so much terrorism vs anti terrorism.
only ever played the training part though...so not sure what the maps are like or where they're based
Pretty much like cs, but shits all over cs to be honest
reason being is that it is heaps realistic, 3 bullets n ur dead, no instant spawn, many different maps, hospital based, artic forrest based, warehouses, heaps
yes was first produced by the army as a recrtuitment tool and has so far progressed
the training is nothin like actually playing
only "downside" is there is no offline, everything is online playing
Hiya guys....
I havent tried Counter Stirke: Source just yet, got the Steam engine exactly 5 weeks ago and have been solely playing Day of Defeat: Source, which is AWESOME.
Im gonna add the [sAU] to my Sgt. Tangles character. I always use the middle machine gun (AK47) known as Support. getting quite aok at it as well.
If you come across me say g'day, and I'll let you in on a secret, Sgt. Tangles has Attention Deficit Disorder and cant stay still, so you'll see me Running and not Camping. :O
But I'll try CS Source next month when I have unlimited broadband and not capped at 500mb.
Brendan
what fps do u guys get on ur source? mine is about 30 - 40 pretty hopeless. ;)  probly coz im having 512 ram.
FPS based stuff in CSS is related to your graphics mainly dude. Decent 512mb ram should be sufficient for frames better then 40. So it's definately graphics. make sure fps_max 100 is on aswell ;)
ive got it on the highest detail possible....
100+ fps
Obviously a half decent graphics card.
I work at a LAN Cafe as a 2nd job, and I play CSS there quite a bit, I will most probably be [sAU] BR3TT :)
I 1.6 at home for the change, as always [sAU] BR3TT will be in place.
Hope to catch one of you guys, I always whore in Game Arena Dust 2 Arena.
;D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
