I've got a 256 mb Nvidia card from last yr, but guess its outdated now. 512mb RAM would definitely make my PC struggling for most new games.
By the way any of you guys do "coding" in CS? :D
cl_updaterate 101
cl_cmdrate 101
rate 99999999999999999999999999999999999999 :lol:
  • Replies 80
  • 2 months later...
I'm An Ozforcces Network Op ( http://www.ozforces.com ) Admin all games hehe.. Counter strike is by far the hardest to op.. And i'm a Mammoth Media a.k.a GameArena ( www.gamearena.com.au ) Referee..
Big gamming nerd haha.. i have 4 dual xeon servers and a decent pc:
AMD 3200+
1GB Geil PC3500
2 x 6600GT SLI Mode
Gigabyte K8N-SLI MOBO
400GB HDD space
  • 1 month later...
CS... no, but anyone here play T2??
After 50K frags in UT I could not keep up the pace and found T2 better to rest ocasionaly while deploying defenses or defending.
OK I know I'm gettin old but still thinking young :D
i cant seem to find any optusnet or gamearena servers..?
i dont camp..
im always the first one it the action
Just go to Optus or Game Arena websites may be they have updated/changed the addresses. Occasionally if I go netcafe I just list the servers from Steam menu and play whateever in there, cant be bothered searching.
OK I know I'm gettin old but still thinking young :O
CS gameplay is already classic, FPS nowadays can have better graphics or whatever but they can never replicate the same impacts CS had. :starwars:
You guys should all sign up at my website!
http://www.counterstrike.com.au/
I didn't even realise SAU had a games section until I looked closer :O BTW, I am mainly found on 3FL as I am an admin on their network (source of course). I should put an SAU section up on the website :starwars:
Edited by ReeceR
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
