OK, thought I should put this thread in to help out others in the future.
A Clarion 4-channel amplifier (edit: installed behind sub)
A Clarion 6-stack CD player fits fine under the passenegers seat, easy to get to.
A Clarion subwoofer in custom box can be easily strapped into the wagon space, and can beremoved when that space is needed.
Head unit: Clarion with tape player, fully adjustable.
Front speakers: Pioneer 6.5inch 4-way speakers, 16cm diameter, 91db, 57mm mounting depth, model TS-A1681S, 260w (fantastic)
Rear speakers: Eclipse 6.5inch 3-way speakers, 80w only but good for 90db, 49mm mounting depth - any bigger & it wont fit due to baffles that are in that rear door area (have been told the baffle stops water getting on the speakers - so dont take them out!)
Standard speakers, as SK has mentioned before, are Clarion 15w, maxed outr at 30w. Mine were terrible. Juncked them in the bin.
The sound is unbelievable. Awesome bass etc. Wicked!!
Make note of the rear door mounting depth..... :D
Best of luck, brendan
Edited by bwilkeson
https://www.sau.com.au/forums/topic/90275-stagea-stereo/
  • Replies 57
I think I posted mine somewhere........
Nakamichi head unit, in the top single din slot
Nissan Pathfinder flip top box in the other (bottom) din slot, silver lid matches the Stagea dash and console surround
Soundstream 4 channel amp 120 watts per channel mounted where the standard stacker goes in the LHS rear 1/4 inner guard (the ATTESA reservoir is in the RHS 1/4)
MB Quart DKE116's in all foor doors
They are 165mm diagonal between the mounting holes and 180 mm total diagonal. Bit tricky to fit as the MB's are perfectly round and the standard speakers are a rounded off square. No problem with depth though.
I use the rear for carrying stuff far to often to have a sub, the MB Quarts do a pretty good job and I am not into doof, doof anyway.
:D cheers :blink:
Edited by Sydneykid
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1628214
SK... i was actually thinking the other day about what amp would fit in that lhs 1/4.... which soundstream model are u running.. an older series or the newer range stuff?
brendan... my r33 came with an amp under the drivers seat.. i found my front seat got rather warm after a spirited session of music listening.....
and the amp came out looking like it had been in the car for 30 years.... does the amp go snuggly under the seat? might consider it under the passenger seat if so..
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1628495
Yeah, well, I had a good look at the system last night, after the post here, and saw that the damn amp was on the back of the subwoofer still (as it was in my VR).
Couldnt believe it, as that wasnt how it was arranged beforehand..... BUT, having said that, the amp/sub box fits extremely well in the LHR rear qrt panel area, right between the wheelwell and the rear door. Almost fluch mounted in line with the wheelwell, so I'll leave it there.
So I'll add an edit to the first post. Yup SK, had read your thread, just wanted to let ppl know about rear door speaker thickness.
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1628809
Well my head unit is a Pioneer DEH-P1Y MOSFET with CD/MP3/WMA capability - 60Wx4 and is mounted in the lower DIN slot - upper slot retained for 3 X guages.
Front speakers are 6" splits - Focal 165KP"s - 80W RMS.
Rear speakers are Alpine SPS 170A's, Co-Axial 2 way - 40W RMS.
The amp is an Eclipse EA3422 - 4 X 50W RMS. The amp hides under the drivers seat.
A bit of a hybrid mix but all components definately compliment each other and produce exceptional soudn quality.
Current plans cater for a CD stacker to go under front passengers seat, but not planning on mounting a sub-woofer - need the back area for carrying.
Marc2
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1628835
The small sub box with woofer and amp sits snuggly behind that LH wheel-well. Still great for carrying loads as it doesnt hinder the space, plus can still have the odd drive-in movie experience!
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1628881
No way I could fit a sub on the rear, I had 8 wheels and tyres in there last week and an RB25DET gearbox. That took up every square inch of space.
The Soundstream amp is about 6 years old. It did good service for about 2 years and then sat unused for 3 years until the Stagea needed its services. I like the sound, not to harsh so it suites the MB Quartz very well.
Is there some difference to the current Soundstream amps?
:D cheers :O
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1629167
SK.. the older soundstreams had very good construction and execellent SQ...
the newer ones just didnt have the same standard as the old ones......
Excelleant, good info, how old is " the older soundstreams"? Is my 6 year old one old or new?
:D cheers: )
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1630917
I made a custom Sub box with 2 x 10" woofers and a 5 channel amp last year, i had pics of it up a while ago but they've gone now. i made the box shaped to the back of the wagon and it fits nicely between the towers and under the boot cover.
In the front i have a pioneer MP3 head unit something, i forget the model number, 5*** series
pioneer kevlar 250W splits in the front, and pioneer 4 way 220W 6" in the rear doors. sound is awesome and can barely be heard outside the car.
i run the splits and subs off the amp, and the rear speakers off the head unit. bit odd, but it gives the best response.
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1631028
Sounds like we nearly have the same system, does your pioneer mp3 player have the blue and orange colours and moving pictures?
I got mine all from ebay and saved a lot of money.
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1631056
It has 2 knobs on each side, it's blue colour but doesn't have any pictures. It's the 5650 i just remembered. my mate has the 5750 and it has the pictures on it. I got it at summernats last year from the JB hifi shop and saved about $300 on it. everything i bought was on massive sale, i'm not a retail-paying chump
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1631111
My sub and front speakers are off the amp, and rear speakers are off the head unit. Good allround response.
I too can hardly hear the doofdoof music when standing outside the car, very loud inside but quiet as outside. Nice.
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1631305
my doors (both front & rear) will be getting a few sheets of this stuff put in when the stereo goes in.
If you want sound deadening, this would be the stuff to go for.
http://dynamat.com/
Sydneykid....have you got any pics of your amp mounting location, as l think mine's gonna have to go in the boot as well somewhere.
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1631416
http://dynamat.com/
I have some pictures of the standard CD stacker that was there before I put the amp in. I just removed the stacker and bolted in the amp, I made up a couple of 3mm aluminium brackets to adapt the amp shape to the stacker mounts. I will take some pictures of the amp tomorrow and post them up.
:) Cheers ;)
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1633249
    • From there it is trickier. Ecutek seems to be one of those closed ecosystems where everyone password protects their tunes which means I either choose a tuner and can't change from them and can't make any changes myself for any reason, or I have to buy the tuning software (about $4k) and then get someone to tune from scratch (which is not simple with all the multi dimensional tables these days). Once you buy about 300 "flash points" per ECU you can get it tuned and add their "RaceROM" function which hacks extra functionality like launch control onto the ECU, and also makes extra data available for logging over CAN Not sure what I'll do there yet; I'm tempted to use one of the overseas shops that does billions of remote tunes of the platform instead of starting from scratch locally, a lot can be done online these days.
    • Can I log IAT eh? Well, can now So next thing was looking at data logging. Not straight forward because none of the motorsport displays have cracked the nissan/inifinti CAN and ECU based displays don't do g logging, lap timing, predictive laps etc.  So, I bought an Ecutek dongle from Tunehouse (Oz distributor). Even without a tune onboard that allows display and logging of about 50 parameters via Android (and presumably iOS) app. Approx 600 for the bluetooth + Usb version That gives me (pretty ugly but) functional dash display on Android And logging of these parameters I'll play around a bit over the break, but at least now I can make sure I have oil pressure when I get to some track testing.
    • I don't know what globes/headlight connector they run, but I'd be looking for a female adapter to plug into the existing headlight on one side. Something like this https://www.ebay.com.au/itm/256017245989 Then I'd use a pair of single input, double output relays (one for low, one for high), mount them in a spare space in the fuse box if you want to to look more original (and be easier to maintain). Then 2 new power sources from the main stud in the fuse box via a fuse to each relay. Low from the headlight adapter pin triggers low relay and high from the high headlight adapter pin triggers high and low. Earth the relays and new headlight sockets and off you go. Because it triggers off the original headlight all of the dipping/hi on/high flash all still works
    • I reached 10 posts and wanted to make my build thread too but still can't add pictures to posts so I have no idea how it works 😂
