OK, thought I should put this thread in to help out others in the future.
A Clarion 4-channel amplifier (edit: installed behind sub)
A Clarion 6-stack CD player fits fine under the passenegers seat, easy to get to.
A Clarion subwoofer in custom box can be easily strapped into the wagon space, and can beremoved when that space is needed.
Head unit: Clarion with tape player, fully adjustable.
Front speakers: Pioneer 6.5inch 4-way speakers, 16cm diameter, 91db, 57mm mounting depth, model TS-A1681S, 260w (fantastic)
Rear speakers: Eclipse 6.5inch 3-way speakers, 80w only but good for 90db, 49mm mounting depth - any bigger & it wont fit due to baffles that are in that rear door area (have been told the baffle stops water getting on the speakers - so dont take them out!)
Standard speakers, as SK has mentioned before, are Clarion 15w, maxed outr at 30w. Mine were terrible. Juncked them in the bin.
The sound is unbelievable. Awesome bass etc. Wicked!!
Make note of the rear door mounting depth..... :D
Best of luck, brendan
Edited by bwilkeson
https://www.sau.com.au/forums/topic/90275-stagea-stereo/
  • Replies 57
I think I posted mine somewhere........
Nakamichi head unit, in the top single din slot
Nissan Pathfinder flip top box in the other (bottom) din slot, silver lid matches the Stagea dash and console surround
Soundstream 4 channel amp 120 watts per channel mounted where the standard stacker goes in the LHS rear 1/4 inner guard (the ATTESA reservoir is in the RHS 1/4)
MB Quart DKE116's in all foor doors
They are 165mm diagonal between the mounting holes and 180 mm total diagonal. Bit tricky to fit as the MB's are perfectly round and the standard speakers are a rounded off square. No problem with depth though.
I use the rear for carrying stuff far to often to have a sub, the MB Quarts do a pretty good job and I am not into doof, doof anyway.
:D cheers :blink:
Edited by Sydneykid
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1628214
SK... i was actually thinking the other day about what amp would fit in that lhs 1/4.... which soundstream model are u running.. an older series or the newer range stuff?
brendan... my r33 came with an amp under the drivers seat.. i found my front seat got rather warm after a spirited session of music listening.....
and the amp came out looking like it had been in the car for 30 years.... does the amp go snuggly under the seat? might consider it under the passenger seat if so..
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1628495
Yeah, well, I had a good look at the system last night, after the post here, and saw that the damn amp was on the back of the subwoofer still (as it was in my VR).
Couldnt believe it, as that wasnt how it was arranged beforehand..... BUT, having said that, the amp/sub box fits extremely well in the LHR rear qrt panel area, right between the wheelwell and the rear door. Almost fluch mounted in line with the wheelwell, so I'll leave it there.
So I'll add an edit to the first post. Yup SK, had read your thread, just wanted to let ppl know about rear door speaker thickness.
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1628809
Well my head unit is a Pioneer DEH-P1Y MOSFET with CD/MP3/WMA capability - 60Wx4 and is mounted in the lower DIN slot - upper slot retained for 3 X guages.
Front speakers are 6" splits - Focal 165KP"s - 80W RMS.
Rear speakers are Alpine SPS 170A's, Co-Axial 2 way - 40W RMS.
The amp is an Eclipse EA3422 - 4 X 50W RMS. The amp hides under the drivers seat.
A bit of a hybrid mix but all components definately compliment each other and produce exceptional soudn quality.
Current plans cater for a CD stacker to go under front passengers seat, but not planning on mounting a sub-woofer - need the back area for carrying.
Marc2
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1628835
The small sub box with woofer and amp sits snuggly behind that LH wheel-well. Still great for carrying loads as it doesnt hinder the space, plus can still have the odd drive-in movie experience!
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1628881
No way I could fit a sub on the rear, I had 8 wheels and tyres in there last week and an RB25DET gearbox. That took up every square inch of space.
The Soundstream amp is about 6 years old. It did good service for about 2 years and then sat unused for 3 years until the Stagea needed its services. I like the sound, not to harsh so it suites the MB Quartz very well.
Is there some difference to the current Soundstream amps?
:D cheers :O
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1629167
SK.. the older soundstreams had very good construction and execellent SQ...
the newer ones just didnt have the same standard as the old ones......
Excelleant, good info, how old is " the older soundstreams"? Is my 6 year old one old or new?
:D cheers: )
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1630917
I made a custom Sub box with 2 x 10" woofers and a 5 channel amp last year, i had pics of it up a while ago but they've gone now. i made the box shaped to the back of the wagon and it fits nicely between the towers and under the boot cover.
In the front i have a pioneer MP3 head unit something, i forget the model number, 5*** series
pioneer kevlar 250W splits in the front, and pioneer 4 way 220W 6" in the rear doors. sound is awesome and can barely be heard outside the car.
i run the splits and subs off the amp, and the rear speakers off the head unit. bit odd, but it gives the best response.
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1631028
Sounds like we nearly have the same system, does your pioneer mp3 player have the blue and orange colours and moving pictures?
I got mine all from ebay and saved a lot of money.
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1631056
It has 2 knobs on each side, it's blue colour but doesn't have any pictures. It's the 5650 i just remembered. my mate has the 5750 and it has the pictures on it. I got it at summernats last year from the JB hifi shop and saved about $300 on it. everything i bought was on massive sale, i'm not a retail-paying chump
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1631111
My sub and front speakers are off the amp, and rear speakers are off the head unit. Good allround response.
I too can hardly hear the doofdoof music when standing outside the car, very loud inside but quiet as outside. Nice.
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1631305
my doors (both front & rear) will be getting a few sheets of this stuff put in when the stereo goes in.
If you want sound deadening, this would be the stuff to go for.
http://dynamat.com/
Sydneykid....have you got any pics of your amp mounting location, as l think mine's gonna have to go in the boot as well somewhere.
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1631416
http://dynamat.com/
I have some pictures of the standard CD stacker that was there before I put the amp in. I just removed the stacker and bolted in the amp, I made up a couple of 3mm aluminium brackets to adapt the amp shape to the stacker mounts. I will take some pictures of the amp tomorrow and post them up.
:) Cheers ;)
https://www.sau.com.au/forums/topic/90275-stagea-stereo/#findComment-1633249
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
