im pretty sure I already know the answer to this however I will ask just to make sure...
on the r33(running standard boost) when your foot is to the floor, on the standard boost gauge where should the needle show a reading to? right up to the +7 or to the line which indicates approx 5.
yours anwers would be greatly appreciated. what does it show on your cars?
https://www.sau.com.au/forums/topic/9030-r33-standard-boost-reading/
Mine used to go up to the 7. The boost will vary on everyones Skyline depending on mods, even exhaust and air-filter will make a difference to boost. Everyone will give you a different value for the factory boost, aslong as you have no boost leak then I wouldn't worry too much, the gauge is only an indicator of on/off boost, not an accurate reading.
See'ya:burnout:
I have a 1996 S2 GTS-T.
100% stock except mags and suspension. When I picked it up from Gold Coast I got a mechanic to look at it. Had the timing belt and water pump changed, coils cleaned, plugs changed etc. It was also put on a computer so all data could be checked. As far as I am aware it is in 100% working order.
Anyway, my car will sit just below the line that is halfway between 0 & +7 up to 4500rpm then it will sit exactly on the line. You can feel it coming on hard at this stage.
For an explanation on the gauge go to (GENERAL AUTOMOTIVE DISCUSSION > correct me if im wrong)
Just to allay any confusion, the factory boost gauge does NOT read in PSI or Bar. If you have a closer look, you'll notice that it is +/- 7 x 100mm Hg. (reading on gauge x 100mm Hg <-- Mercury).
1 lbf/square inch (PSI) = 51.71507 mm mercury (0 C)
10psi = 517.1507mm Hg or the position approximating 5 on your factory boost gauge.
In saying all of that though, the factory gauge is pretty innaccurate at best and should prob only be used as a guide. Hope this helps.
out of interest, if 1 bar = 14.503774 lbf/square inch (PSI), does having 7.251887psi mean you have 'half a bar'?
I found the perfect pressure conversion chart...it covers all pressure standards.....i.e. standard meter +7 = (about) 13.5 psi, anyway it backs up all that is said in this thread. I have a laminated copy in the car for just those times when u ask...whats that in PSI (or in this case mmHg)
You can find it at http://www.aquaticam.com/presschart.html
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
