There is an EXTREMELY detailed and very good write up about anti-lag systems in Zoom magazine No. 59...
The anti-lag is stressful on alot of the exhaust parts (turbo, valves, manifold, exhaust, cat)... These days if you buy a good turbo like a Garrett, Trust or HKS they can withstand the anti-lag... But i wouldn't even dream of running anti-lag on the standard nissan ceramic turbo, it would blow it to pieces...
Well if your already running rotational idle you should already have a 10-15% opening so you wont need the kicker solenoid...
When the anti-lag is working the engine retards like 20-40degrees (on some cars) and dumps a heap of fuel into the exhaust manifold which then ignites on the hot manifold and more importantly on the turbine wheel which then produces boost... The car won't be ready to produce boost, it is producing boost...
Yes anti-lag is beneficial at the drags coz for the launch you want the turbo to be fully spooled for when you dump the clutch...
  • Replies 41
GTS-t VSPEC, so you are running a Wolf computer, can you tell me your experiences with it,
Its at the top of my list for ECUs right now. Looking at buying one in about 2-3 weeks. I havent read anything about them having rotational idle, or any other functions you mention.
Are the memory cards that easy to change over, what $$$ are extra cards worth.
Id like to have a Map setting to run say 12psi on road on 98 octane fuel, and the a track MAP setting to run 1.3bar on VP race fuel.
I ran MT8 on my old Skyline and was never happy with the quality of the tune you could get out of it. Not the most accurate fuel delivery and no matter how much tuning (by experienced tuner) you coudnt get it returning any decent economy figures as the thing didnt run closed loop. Sure did the job though when foot flat to the floor:D
  • 5 months later...
Originally posted by Dragon
Hmm, I was running rotitional idle and anti lag on my little GTti.
Rotational idle was used to spool up the turbo on a standing start. >12psi from the word go! (Then it would hit 26psi @ 5,500rpm)
Anti lag was used between gear changes to keep the rather large hybrid turbo spinning.
I would use the rotitional idle as a crude form of launch control. The MoTeC M4 Pro was set to cut the coil packs, but still allow fuel to pass through.
While staging, you would hit the launch control button on the steering wheel, engage 2nd (Never first gear) clutch in, and foot flat to the floor on the loud peddle.
The MoTeC would hold the revs around the 5,000 rpm mark, but keep on cutting the spark to the cylinders at random. While the throttle was wide open, the resulting pulsing from the engine would cause the turbo to spool while you are standing still.
As soon as the clutch engaged (A micro switch on the clutch peddle) the MoTeC would then switch off rotitional idle and run the proper maps. (IE: 9,500rpm cut, and anti lag turned on)
I used rotitional idle to gain boost while standing still.
Worked VERY well, but produced 6 foot flames out the back. (Cat died a long time ago)
Had a 5-8 second window of using rotational idle, over that, everything started to heat up badly.
Anti lag 'can' be used to get the turbo to spool up before launching, but is a very crude form of doing this, since you have to rev the engine right up, then lift off the loud peddle to get the antilag to kick in.
At least with rotitional idle, I had the throttle wide open all the time!
WOOOOO DUDE"S!.... I think I've seen this car. its being a few years but, there was this little blue GTti charade that used to blow the doors off V8's and WRX in the ACT... the driver was a nut bag :) .... Man you had to see this little machine fly
Its couldn't be the same car could it? your in Qld
    • You have found the problem. The wire from the switch to the HB is shorted to earth. Now you have to physically find it and replace it. It won't be the switch, although following the steps above (and yes, where you ask, that is the light switch on the RHS of the binnacle) will rule it out for sure. Or not, if perhaps the switch has melted. But there's no route to earth inside the switch, so I can't see how it would.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
