hi ive got an 85 r30 four door,im currently in the process of building an rb30det for it , what i want to know is the rb gearbox easy to fit.
Like does the gear lever line up with the whole in the floor pan and do i have to change gearbox mounts ...
if anyone could shed sum light i would be most of appreciative...
Thanks
Sam
https://www.sau.com.au/forums/topic/90356-r30-rb30det/
the rb20 box shifter sits back about 1/2 an inch past the end of the existing hole
i dont mean to be a cheeky bastard but what did you do when you fitted youre RB25DET did u move the engine forward or cut out the floor pan ... please enlighten me
Thanks.
Edited by EVLR30
https://www.sau.com.au/forums/topic/90356-r30-rb30det/#findComment-1635358
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
