Yesterday I came back to my car to find that it had been broken into (no sign of forced entry). Ignition barrel was ripped out and broken. Fortunately nothing was stolen. Strange thing was that my club lock was still on the wheel...
Thank God for monitoring alarms...
For those who want to know I was parked on Homebush Rd in Strathfield, about 2 blocks from the train station.
https://www.sau.com.au/forums/topic/90385-almost-stolen/
i've seen your car i fink .. it's like 2 corners around from the shell? I've parked my car there once visiting a friend.. didn't realise it's a dodgey area :):O
hard lucl :)
https://www.sau.com.au/forums/topic/90385-almost-stolen/#findComment-1629747
yeh i agree guys get ur selves a good alarm, and for those who have the shock sensors set to sensitive, i dont know how u could handle that, doesnt it get annoying?
i have mine set just enough so that if you lean on it it goes off.
https://www.sau.com.au/forums/topic/90385-almost-stolen/#findComment-1636654
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
