I just put my track spec Z in for it's 40,000 major service (39,600) and told the guys at the Nissan Dealership In Woden to look at the brake pads as they would probably need replacing given the kilometers on the car. I got a call a couple of hours after I dropped the car in and the guy told me I needed new front and read brake pads and also front and rear rotors at a total cost of $5,800.
Several things:
- Have any of you guys ever gone through a set of rotors (front and rear) in 39,000km's without ever machining them?
- If that's what the genuine Brembo options costs from the dealership I think I will give it a miss. Where do you guys go in Canberra to get this kind of work done? Do they order the parts in or will I have to buy them and then take them in?
P.S christ... $5,800 on what is a fairly new car. I wonder what it would be worth to replace the whole lot, calipers and lines etc?
https://www.sau.com.au/forums/topic/90397-brake-padrotor-question/
Genuine Brembo pads are pretty harsh on the rotors and I wouldnt be suprised if the rotors were stuffed. Whats actually wrong with them, are they just worn, warped or weakened? If they are worn you can possibly get them machined, if they are warped you can get them machined depending how bad they are warped, if they are weakened (massive heat spots, cracked etc due to stomping the brakes when theyre cold and holding the brake pedal down when your stopped and theyre hot) then they will need replacing.
I run DBA 4000 discs with Racebrakes RB74 pads and it works a treat. You can get the DBA discs from DBA directly or Super Cheap (custom order, but they generally have jack all markup on them and are cheaper than brake specialists) and the pads from www.racebrakes.com.au. You should be able to get a set of good pads and discs for $1000 - $1500.
Thanks for the advice. The rotors weren't cracked or warped they were apparently just worn down so far they can't be machined... this is what I find hard to believe. Oh well, i'll look into it.
Another thing I need to keep in mind is the new car warranty it still has 38 months of it left. What are Nissan going to say if I go putting non standard parts in? You can bet if there is ever a problem with the calipers/brake lines etc they will just blame the after market pads and rotors...
You might not agree with me here, but my dad and a couple of mates have z-series cars.. and it seems that even the simplist thing with them costs a bucket load to fix..
$5800 is absurd. call the place you bought it from and ask them why they didn't tell you that you could expect that. considering it's 10% ish of the cost of the car no one would buy a z if they knew it was gong to cost that much after such little use.
dba/rda discs and ferodo ds2500 pads work well for me
Somehow I don't think they could give a shit wether I like paying the $5800 or not, to them they would just consider it standard consumables. They have my 75k, that's all they seem to care about. I will talk to Nissan Australia rather than the local dealership but I don't like my chances.
hey did you post this up on my-350z as well? coz I saw a similar question the other day?
Anyway, you can get BDA 4000 series rotors about 200ea and Bendix Ultimate pads about $400 front and rear. Do the change yourself about 2 hours or get any mechanic to do it, its dead easy.
Unbolt the caliper, pull the disc off, slide the new one one, put the caliper back on, pull the old pads out and shove the new pads in. Repeat x4. The rears are a bit trickier and you might need to use a bolt to pull the disc off over the drums.
I posted this on the 350z-tech.com forums as well. I thought i'd ask around on these forums as you guys are local and know the good places to get work done.
Have a chat to the dealer and then to nissan and explain that it may not be good publicity if these kind of stories make it into the mainstream media. A set of discs and pads would be cheap for them compared to the sales they may lose if this becomes common knowledge.
Toyota had a problem over 10 years ago with the turbo diesel landcruisers hammering out bearings and it was looking like a real problem, they turned it around by replacing the bearings and fixing any cars that had this problem. They still cover the problem now, 10 years or so later because they cant afford to lose the buyers.
Did you see there is a set of front brakes for sale on the parts for sale forum on here?
I run the same, but why are yours soo much quieter than mine???
Also i found Jake's performance to be able to supply my discs A LOT ($300+) cheaper than supacheap/autobahn/autopro/repco etc...
They make a loud grinding noise when you get on them hard, which is normal. To get rid of the squeak you need to bed them in hard from the start (do one 60kmh - 20km/h slow down to start, then stomp them hard from 100km/h+)
That price they have quoted you is a joke $5800 for pads and rotors, What the hell  are they gonna do for that kind of money?
They are magical disks and rotors sprinkled with pixie dust based on that price. ;)
Thanks for the suggestions guys. It looks like i'll be going with some DBA 4601's for the rotors at around $300 each... compared the the Brembo ones at $1200 each. Still not 100% sure one what I will be getting for the brake pads... suffice to say, not the Nissan ones for $800 ;)
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
