  • Replies 41
lol bathurst - "The Bathurst 1000: Which Commdore or Falcon Will Win?"
The one with the huge spoiler and sounds like a v8 ;)
btw you mean "commonwhore".. i see them every where and every day, every model has pretty much the same characteristics as each other.. hopeless chunk of metal.
Michael.
