Below is two pics of the GT35r (GT35/40R) turbos.
The one on the left has the .5 front cover as it came off the ford xr6 turbo.
The one on the right has a .7 front cover supplied aftermarket.
The turbo on the left (.5 ar front ) has a hose going from the actuator to a bung on the compressor cover, where the 0.7 cover one on the left doesnt have this at all.
Where do you need to attatch the hose coming off the actuator if you have the 0.7 front cover?? Somewhere after the outlet of the turbo on the pipework?
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/
  • Replies 43
Posted Images
cool. Now for another question :O
Is it just a simple job of swapping the 0.5 cover for a 0.7 cover between the two turbos?
Ive heard so many people say they are different specs, but are they different, or the same? ie, if i bought the one on the left, could i unbolt the front cover and swap it for a 0.7 ar front?
Edited by Bl4cK32
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1629830
No , the .50 cover is T04E series where the .70 is T04S series . You would need to change the back plate/adapter ring as well . These butt up to the flange on the comp side of the cartridges bearing housing , are sealed with an O ring and held in place by a large circlip .
Try to buy it as you want it because the bits are not always cheap , when I inquired through GCG Brett said he could supply any of the three .50/.60/.70 "E" covers or the .70 S cover for the same price .
Cheers A .
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1629994
Ok, now ive got a good question disco (or anyone else) :
what is the difference between the T04E and the T04S covers...and when comparing same size covers - 0.5 T04E vs T04S?
(Also disco, what would you say would be the best on my motor, the 0.5, 0.6 or the 0.7?
What would be the difference in power spread over the 3 covers?
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1632295
If you're looking to make fairly big power figures i.e. 300kw plus then you'd want to keep the .7 cover for the simple fact that it efficiently flows more air which is whats needed for big power and turbo reliability.
Anything under 300kw the .5 cover would be fine but thats pushing it.
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1637173
hrmmm .6 you say disco.
I would still prefer the .5, you will need all the response you can get with the 1.06.
The XR6 boys don't seem to have trouble cracking 320-340rwkw on the .5 comp cover. More than enough for the stock rod rb30. :)
Then again... The .7 comp gt35r 1.06 turbine will still have better response and spool time than an rb20det with a highflow or 2530 on it. :blink:
Edited by Cubes
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1637534
Well i guess you should talk to GCG then, as they think differently. I emailed them and they said :
Thanks for the enquiry. For an RB30, I would suggest using the 0.60a/r Compressor Cover for your application. The difference between the 0.5a/r covers throughout the the T04 Range is the inlet and outlet sizes, and designs of the covers. They would all work in the same way, and produce similar, if not the same figures. We have had good success with people keeping the standard 0.70 T04S Compressor Cover, but you can drop to the 0.60 for better response
This is on a street driven car.
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1639618
I would use it as is....
I mean try and if no good then swap em over....
There is just too much hear say on these topics....
I was told a standard r33 turbo on an rb20 would not produce a cent over 180rwkw and i got it too 230rwkw.... So who know's????
I would take Bretts advice as a starting point but if your un happy with the results you can always change it....
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1640890
Fatz made 270rwkw on 14psi with an untouched rb26
ecu running 10:1 afrs.
If the motor has forged rods then I would say the .6-.7 a/r cover would be worth while.
Remember with the .5 on the 3ltr its not going to really start going until 3800-4000. Is it worth making it even laggier and less responsive?
Edited by Cubes
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1643473
I'll trust fact that GCG know what they are talking about. Ford used the 0.5 front as it was a low boost application to keep the power down. (am i right...lol?) I think the slighlty bigger compressor (0.6 front) will be a bit better for a little more (14 to 19 psi) boost than Ford was running. If i wanted more boost again (ie 20+ psi) id go for the 0.7 front....thats my theory anyway, and im sticking to it :P
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1643533
The reason Ford used the .5 comp cover is for response, nothing to do with keeping the power down or because it is a low boost application.
There is no doubt the larger comp cover will be more efficient and make the power easier but not that much.
As a bodgy comparison...
Consider the GCG highflows, the stock rb comp cover makes say 245rwkw odd. Slap on a .7 and it makes 260rwkw.
Thats 15rwkw.
Then consider dropping on a larger turbine housing, 245rwkw or so jumps to 277rwkw.
What I'm getting at is the biggest gains are to be had from the turbine side, not the compressor cover.
From what I've been reading up on, the larger .7 comp cover only offers 3-4% increase in power.
I really think your better off spending the $$ on a nice set of cams and springs that will need doing and pick your self up a second hand $1400 XR6 turbo.
Cams with the large turbine housing will work very well.
I think from more of a performance to $$ point of view.
Edited by Cubes
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/#findComment-1643658
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
