gonna keep an eye on this thread myself as im waiting to c how my t04e with 0.5 a/r comp cover n 1.00 a/r rear housing goes on my rb30det. on the stocker rb25 it hit 1 bar at 3500.... interesting...
im thinkin upgrading the housing to a .6 or 7 n maybe the front wheel also... wat u guys think? the goal for it is 350rwkws, anything more is a bonus
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/page/3/#findComment-1664629
  • Replies 43
Posted Images
id say wheel sizes are more important than ar's ;)
Quite right, but the trouble is knowing what wheel sizes actually mean.
Look at a 40 year old design of exhaust turbine wheel like a T3. It is shaped like a biscuit, large diameter and skinny around the peripheral edge with the vanes aggressively swirled at the outlet.
Compare that to a more recent ball bearing turbine like a GT25 which is more cylindrical in shape. It looks more like the paddle wheel off a riverboat. Smaller diameter with straighter vanes and a much bigger outlet area. The trim numbers are much higher. The old wheels are like 40 trim to 60 trim, the new ones more like 65 to 90 trim.
Trim is the ratio of areas of wheel outside diameter to eye diameter.
The old skinny wheels had higher tip speeds requiring smaller a/r housings. The flow range was less and they are more difficult to match to different engines. The wheels were heavier too.
New wheels flow much more and have a broader flow range, less rotational inertia, and are much more efficient.
A T3 has a bigger turbine wheel than a T25 (or a T20). The T3 is even bigger outside diameter than a GT25, but the GT25 turbine is a MUCH higher flow turbine than a T3. So actual wheel diameter is not a very good guide to flow when comparing old turbos to the newer ones.
If you want to work out wheel trim and you know the eye diameter (say 41mm) and the wheel outside diameter (say 53mm).
41 x 41 = 1681
53 x 53 = 2809
1681/2809 = 0.598 that would be called a 60 trim wheel (59.8 actually)
So you can see a 40 trim wheel is pretty skinny and a 90 trim wheel is going to be pretty fat. There is no way you could compare them just by overall diameter, but that is what Garrett does. A GT28 is a hell of a lot different to a T28.
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/page/3/#findComment-1664677
Some of that is right and some a bit controversial .
You can't really separate the turbine and housing and say one is more important than the other , they are a matching pair working together .
The whole GT28BB is better than T3 thing is because the light weight high speed rotating assembly can move the same or more gas wth less exhaust energy and restriction while being more compact . The ball bearings have less drag losses , particularly at low shaft speeds , but far better shaft support and longer life .
Compressor trims for the GT wheels are mostly between 48 and 56 and turbines 62 and 90 . 76 to 84 seems to be the sweet spot .
Garrett list 6 six bladed 60mm T3 compressors from 35 to 60 trim . There are so many variations in what people loosely call T3 turbines that its not funny .
Its safe to say that GT BB turbos are generally wider range devices but if badly speced or sized don't expect top shelf results .
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/page/3/#findComment-1666667
KamikaziR33 I do remember one Jurasic turbo that seemed to work on an RB30ET . It used a split pulsed (twin entry) T3 flanged 1.00 ARR T4 housing/Ptrim turbine . The compressor was a 60-1 in its native cover and back plate . The word was it tore up the pavement at 10 lbs boost . The std exhaust manifold had a fitting welded to it and a 42mm external gate .
The single cam motor used a stage 3 camshaft and idled like a chaff cutter .
This was about 6 or 7 years ago .
https://www.sau.com.au/forums/topic/90432-xr6-gt35r/page/3/#findComment-1666736
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
