With a GTR front cut is it possible to make a GTSt 4WD? using the gearbox,front drive shaft, front diff and axles, also the front hubs????? will all the parts need be included in a front cut???
Obviously the gearbox tunnel would be modifided to make room for the trasfer case and you would have to put in the torque spit control in, but in theory its possible, and borderline worthwhile.
https://www.sau.com.au/forums/topic/90457-how-to-make-a-r33-gtst-4wd/
Its physically very hard. I checked out a r32 gtr shell and compared it to mine (gtst)
Basically the front chassis rails in the engine bay are completely different. They have like a upside down u to let the front driveshafts have room to clear . Then inside the car on the drivers side there is a hump to let the transfer case have clearance as well.
In other words, unless you are prepared to do a cut and shut on the front end, and modify some of the floor pan its a very hard job imho. Otherwise go for it :P
And would the rear gear ratio of the GTSt match the front GTR ratio? They have different driveshafts so a full rear change would be in order.
I know there is a large difference on the R33 GTR I have and my manual GTSt. The GTSt with higher redline of 8000rpm with PFC is doing 60 in 1st and 105 in second, while the GTR on stock computer does 75 in first and 125 in second which, while I couldn't be arsed checking the ratios myself is more than the the slight difference in redline.
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
    • Righto,  enough of ADHD Anonymous! 🤣🤣 Rear end is completely stripped out apart from coil overs that will take 5 minutes.  Fingers crossed it doesn't look like that for too long!   Cleaning up some bits as I go so they can go straight back on. It amazes me how good stuff looks just with a good hard scrub! That will be it for a couple of weeks. I've got ot a bit of surgery Friday that will put me out of action for a few weeks. Hopefully the motivation is still there when I'm ready to get back into it!
    • The povo spec CA18S one, yeah. All turbos had 16x6.5 5 stud and 4pot brakes.
