lets make a date to meet up and go with it ...ive been doing this up for nearly four years in that time this car has probably done 4000 km everytime i finish one thing i find another thing to do and its always off the road waiting fo parts ...... it never ends.... but the reason i am putting the 6 speed dog box i am after 800 hp with the twin td06 set up .....
the need for speed....
  • Replies 109
Posted Images
i have 19'' wheeles so traction is a thing of the past but on the track i have micky thompson radials.... its still only single turbo i am still waiting on the other one from the land or the rising sun...
Absolutlly love it.....
Looks horn under the hood.....
Similar to what i have planned and have purchased....
I do wish to know a little more about the ignigtion system....
What coil pack are u using and its the MSD controller.... How did that work out.... I assume a map sensor was introduced but what sort of ecu are you using now???
post-7531-1129380872.jpgpost-7531-1129380945.jpgawsom its got 14k worth of upgrades running digital 4 ignition 6 v8 supacoil packs 3 seperate bosch ignighters with two msd amplifiers all up putting out about 450000volts tell me thats not enough spark....
post-7531-1129455922.jpgpost-7531-1129456097.jpgwell i bought the gts and started doing some mods i put a few things like motec m8 pro race seats actually pritty much the same as in the pics exept i had a t51rspl and payed a guy to do all the work but instead he sold all my parts i went to c the car he wasnt home went out the back and their it was stripped nothing left but a shell ... but of coarse he told the investigaters that i took everything so they said his word against mine so i got nothing ...so instead of a shell i re did it back up to what it is today with what was stolen it owes me around 120000i no its alot for a gtst but i love it and i couldnt just waste a r33 so thats the story .... if someone buy the name of george ross lives in ferny grove wants to work on your car not a good idear...... it took nearly three years to get it back to what it is now ..i dont have anypics of the interious but emagine a empty inside ...
ohh man thats one story we dont like to hear hey
how 'good' are these coppers we have these days, u reckon it woulda been a different story if it was an owner of a brand new ferrari and the owner was some famous business man
i look foward to seeing it mate :)
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
