Did anyone go? Anyone watch it?
I just got back from spending a couple of days up there and it was awesome.....
Gotta love the yobbos on the top of the hill..... pitty no women took them up on their "magic Carpet Ride" which consisted of a piece of carpet with a hole in it :P
The weather is ever changing.... sunny bottom, freezing top.... some good grid girls to look at and the new pits are awesome.....
I think ive set a new record... Cracked open a burbon and coke at 5AM.... was sitting with my mate in about -10 degrees in our good position on the main straight and it had to be done..... trust me at 5am the place was reasonably packed.....
Pitty about the result.. i was looking forward to seeing lowndsie up the top... it was a feat in itself getting that car to finish with missing front windscreen, rear windscreen and drivers window......(sports tonight to find out why)...
Sorry about the lack of layout in my post..... ive just got home after driving since 5 and had maybe 2hrs sleep last night.....
The bogans were blowing up stuff all night which shook cars and set off alarms in the surrounding streets :)
Ed
https://www.sau.com.au/forums/topic/90501-bathurst-10002005/
The "heated exchange" between Ambrose and Murphy was interesting....
I was half hoping that Murph would deck Ambrose when they had their little standoff after their incident. It would have served Ambrose right as he is the most arrogant piece of work going around in the series...can't say I felt sorry to see his car on the back of a tow truck either :)
Was a fairly good race overall, but I couldn't believe the amount of incidents that happened during the first half of the race. You would have thought it was a sprint race they way some of the drivers were acting.
Good to see the red car back at the front where it belongs :P
pff red car :P dont get me started.......
Everyone was yelling for them to deck each other it was awesome.....
This was a ford year..... i saw so many FPV cars on the way there, parked and way back and saw maybe 2 hsv's.. weird huh.....
Channel 10 missed both lowndes incidents... you would think that with so many cameras they would have captured it all.
How unlucky was lowndes and how luck was not to be hurt.... can be pretty nasty when a wheel goes through your window
Yea I was down there :D I had a seat just on the end of the main straight...looking up Mountain straight....was there at 4am....loads of people there too!
Great race...Good to see Skaife back on top
But damn! No bloody sleep....I was camped the back of a Volvo XC70 next to some bloody piromaniacs from Blacktown....Didnt sleep at all :P
But overall....top few days :blink:
it's a pity about Jim Richards and James Courtney... I was looking forward to seeing how Courtney would go.. he's a top driver
Top driver or not, I don't think Courtney will be getting a start in another AUS enduro any time soon - there's no excuse for fcking it up by trying to hard that early on in a 6 hour race. Plus he deprived us of the chance to see Jimmy on the track!
I would have liked to see Lowndes win (yep, I'm a secret Ford Fan from way back). The first mistake was his fault, but the tyre through the windscreen was the worst bit of bad luck I've seen since Jimmy's visit from Skippy last Bathurst!
Also nice to see Ambrose come unstuck - I used to be a fan but his arrogance this year has been astounding! Murphy's not much further up that food chain, so I guess it couldn't have happened to two more deserving blokes!
Kel
Yea I was down there :( I had a seat just on the end of the main straight...looking up Mountain straight....was there at 4am....loads of people there too!
But damn! No bloody sleep....I was camped the back of a Volvo XC70 next to some bloody piromaniacs from Blacktown....Didnt sleep at all :D
damn you must have been 30m away from me...... i was camped in the skyline.. passenger side... watching pimp my ride trying to get to sleep with the bombs going off..... :)
Damn...didnt see ur skyline down there...shoulda come over and said hello :blink:
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
