Put a boost tap in last week and have been playing round with it. My car only has the standard gtst intercooler. Could someone experienced and mechanically minded tell me what the max boost that I should run it on without the intake temps getting too high or the a/f mix becoming lean. Seems to hold 12psi fairly well.
Cheers
https://www.sau.com.au/forums/topic/90503-winding-up-boost-on-a-33-gtst/
I personally run ~9.5psi with full exhaust and it's fine.
With summer coming, I wouldn't want to run anymore through the standard cooler personally. You're risking too much money for a couple of extra KW :D
huh, i personally wouldnt go over 11 psi to be safe with a bigger intercooler
13 is to much for stock turbo
Not worried about the turbo. It puts out fine. Im worried about the piston and rings. Thats it.
One other question. Is the car speed limited? I've nearly reached the top of 5th and haven't found one, yet people tell me it's limited to 180km/h.
serious? u held 14psi wit standard ecu, standard computer?
god mine wouldnt even let me get to 14psi...cuts out
not even 12psi
well count urself lucky, if the ecu let u do that, u would soon have no turbo, and possibly more problems, 12psi is within the limits, possibly even 11psi, push it more and ur asking for some trouble
are you really doing 180 ?
when they are imported they are fitted with an 180km speed limiter as part of compliance, this is easily bypassed and removed, so its possible that its removed, technically u shouldnt be able to top out 4th (on a manual)
which i have never tried, cause those speeds on the road are a little bit stupid u know ...
10psi for me, never any more.
and if u reached the top of fifth(250km/h) u have your speed limiter removed
at higher boost you should worry about your turbo not your motor. the standard ecu will go rich and retard and it should feel slow anyway.
not even 12psi
lol... my car is well looked after. Im an apprentice mech.
plus I put out the exta dosh for bp ultimate :D
Not to mention that the turbo would be working harder to push that much air through the stock cooler (as I've been told they are pretty restrictive)
Personally, I'd recommend no more than 10psi. Who knows, if your turbo blows, you could end up with nasty bits in your engine, not really worth it....
Thanks Tomm0. This is exactly the sort of stuff I want to find out. Thats something I haven't thought about. What damage could it cause if the turbo blows?
it does not matter what fuel or what u are, if u run 14psi the turbo is sure to die soon after some hard use. do a search on stock turbo and u will see why, but simply put, the exhaust wheel is ceramic, and does not handle heat well.
haha whoaaa watch out people, hes an apprentice!!! lol just joking, yea i use the good fuel also...
Coupe This: i had no intention of running 14psi! it was set to 12psi....held it flat up a hill...major cut out, dont want that again, dont even want it at 10psi, raising the boost wit mostly standard parts dosnt enhance performance at all, car runs slower at any boost above 9 or 10 or 11....its set at standard until i put my power fc, bosh 040 pump, fuel presure reg and cam gears in, than i will have it at a max of 12psi
It's more a matter of keeping the heat as low as possible. The figure most people use is 13psi, but if you go on track days it might blow up at 11psi due to the heat, simply too hard to predict.
With a FMIC, most people run 12psi without any problems.
Dont intend on going to track days until I have all the stuff to handle long periods of high load. At the moment I only give it hard for a couple of minutes at a time. Or drag it on the quarter mile.
Cheers for the productive answers Tomm0
10psi sound like the go till FMIC is in then i'll see how 12psi goes.
Edited by r33nut
I would have wagered a bet that your turbo would have blown within the month if you kept it running at 14psi.
Its all about what you want: A quick high or reliable buzz?
I dont really understand how it works but from what I've read, the stocker experiences diminishing returns after 12psi.
Personal recommendation? I reckon keep it at 10psi until you get a FMIC, especially with the hotter summer days approaching.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
