Put a boost tap in last week and have been playing round with it. My car only has the standard gtst intercooler. Could someone experienced and mechanically minded tell me what the max boost that I should run it on without the intake temps getting too high or the a/f mix becoming lean. Seems to hold 12psi fairly well.
Cheers
https://www.sau.com.au/forums/topic/90503-winding-up-boost-on-a-33-gtst/
I personally run ~9.5psi with full exhaust and it's fine.
With summer coming, I wouldn't want to run anymore through the standard cooler personally. You're risking too much money for a couple of extra KW :D
huh, i personally wouldnt go over 11 psi to be safe with a bigger intercooler
13 is to much for stock turbo
Not worried about the turbo. It puts out fine. Im worried about the piston and rings. Thats it.
One other question. Is the car speed limited? I've nearly reached the top of 5th and haven't found one, yet people tell me it's limited to 180km/h.
serious? u held 14psi wit standard ecu, standard computer?
god mine wouldnt even let me get to 14psi...cuts out
not even 12psi
well count urself lucky, if the ecu let u do that, u would soon have no turbo, and possibly more problems, 12psi is within the limits, possibly even 11psi, push it more and ur asking for some trouble
are you really doing 180 ?
when they are imported they are fitted with an 180km speed limiter as part of compliance, this is easily bypassed and removed, so its possible that its removed, technically u shouldnt be able to top out 4th (on a manual)
which i have never tried, cause those speeds on the road are a little bit stupid u know ...
10psi for me, never any more.
and if u reached the top of fifth(250km/h) u have your speed limiter removed
at higher boost you should worry about your turbo not your motor. the standard ecu will go rich and retard and it should feel slow anyway.
not even 12psi
lol... my car is well looked after. Im an apprentice mech.
plus I put out the exta dosh for bp ultimate :D
Not to mention that the turbo would be working harder to push that much air through the stock cooler (as I've been told they are pretty restrictive)
Personally, I'd recommend no more than 10psi. Who knows, if your turbo blows, you could end up with nasty bits in your engine, not really worth it....
Thanks Tomm0. This is exactly the sort of stuff I want to find out. Thats something I haven't thought about. What damage could it cause if the turbo blows?
it does not matter what fuel or what u are, if u run 14psi the turbo is sure to die soon after some hard use. do a search on stock turbo and u will see why, but simply put, the exhaust wheel is ceramic, and does not handle heat well.
haha whoaaa watch out people, hes an apprentice!!! lol just joking, yea i use the good fuel also...
Coupe This: i had no intention of running 14psi! it was set to 12psi....held it flat up a hill...major cut out, dont want that again, dont even want it at 10psi, raising the boost wit mostly standard parts dosnt enhance performance at all, car runs slower at any boost above 9 or 10 or 11....its set at standard until i put my power fc, bosh 040 pump, fuel presure reg and cam gears in, than i will have it at a max of 12psi
It's more a matter of keeping the heat as low as possible. The figure most people use is 13psi, but if you go on track days it might blow up at 11psi due to the heat, simply too hard to predict.
With a FMIC, most people run 12psi without any problems.
Dont intend on going to track days until I have all the stuff to handle long periods of high load. At the moment I only give it hard for a couple of minutes at a time. Or drag it on the quarter mile.
Cheers for the productive answers Tomm0
10psi sound like the go till FMIC is in then i'll see how 12psi goes.
Edited by r33nut
I would have wagered a bet that your turbo would have blown within the month if you kept it running at 14psi.
Its all about what you want: A quick high or reliable buzz?
I dont really understand how it works but from what I've read, the stocker experiences diminishing returns after 12psi.
Personal recommendation? I reckon keep it at 10psi until you get a FMIC, especially with the hotter summer days approaching.
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
