  • Replies 51
  • 3 weeks later...
It depends on you that how much you want security and how much you can pay for that.There is variety of security devices.Like you can use hidden alarm lock that will triggered when the door will open without keys and other alarm system that disable your electrical components to work if open in unfair means.
out of curiosity what is your origin and background?
  • 3 weeks later...
well, to breath a bit of life into the thread, im also looking at getting a full alarm system into my r33 gtst...
was looking at Autowatch and Mongoose (maybe Viper)... just wondering what the general consensus is on these brands???
want atleast 3 point immobiliser and integrated turbo timer (or atleast turbo timer friendly).... automatic window winder would also be nice =)
also, any suggestions as to who would be the best to install the system without screwing it up would be awsome!!! im in NSW, so whoever is around the sydney area would be great.....
Suggestions pleaase guys n gals!!!
Hello Chris,
you wouldn't per chance have similar advice for a Melbournite ??
Any assistance greatly appreciated - by pm if preferred.....
Thanks (in advance)
The Baron
Auto watch. Security in motion. Google that.t
  • 1 month later...
Hello Chris,
Thanks (in advance)
The Baron
Thread bump
Had a look at the products you mentioned
I have no idea on which product, is there a particular model you recommend Chris?
Also looking for a Melbourne Installer that you recommend
Feel free to PM (spose so everyone doesnt know what alarm I use and who did it lol)
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
