Quick calculations would suggest that the piping configuration has an extra 45° bend over your standard 'up and across the radiator fan' config. I am only counting the bends on the outlet piping here, and assuming most people use the factory route for the inlet (to the cooler) piping.
Cooler to TB piping only:
The config in that pic has 1 x 180°, 4 x 90° and 1 x 45° bends = Total of 585°
Routing between engine and radiator fan has 6 x 90° bends = Total of 540°
Routing back to the factory locations has 1 x 180°, 2 x 90° and 4 x 45° bends = Total of 540° (well mine does anyway)
So the piping in that pic does have more bends than most layouts but whether or not the lenght of piping used is more or less is difficult to guess. I suspect when you add it all up there isn't much difference (length wise) between the 3 setups.
I have no idea what the laws of physics say about pushing air around a 180° bend as opposed to a 90° one but surely the sum of all the bends must have some bearing on velocity of the air and lag/throttle response etc.
Every bend causes a slight pressure drop, additional length/volume detrimentally affects throttle response (NOT the same as lag), so yes that would be worse off. But by how much? Well not a lot, i think it looks quite neat and it gets extra point for being different.
Gives you more torque if you can queue up the air in a nice straight line.
Why?
IMO the only real benefit of not having a bend in before the TB is to prevent any unusual flow patterns from messing with the distribution of air to each cylinder, and I tend to think this would be a small, if not negligible effect in the majority of situations. If you wanted to be pedantic, the safest bet would be to stick with the factory piping, as that's the only configuration thats had any real R&D.
I also don't understand your comments about air "backing up" at the throttle plate.
Don’t worry dude just stating an opinion, I don’t really care to discuss this boring topic in great detail. The standard setup is better I believe and it has a nice straight run off the throttle. If you like the windy piping in the Kermit car then cool, the difference it makes is insignificant anyway.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
