Quick calculations would suggest that the piping configuration has an extra 45° bend over your standard 'up and across the radiator fan' config. I am only counting the bends on the outlet piping here, and assuming most people use the factory route for the inlet (to the cooler) piping.
Cooler to TB piping only:
The config in that pic has 1 x 180°, 4 x 90° and 1 x 45° bends = Total of 585°
Routing between engine and radiator fan has 6 x 90° bends = Total of 540°
Routing back to the factory locations has 1 x 180°, 2 x 90° and 4 x 45° bends = Total of 540° (well mine does anyway)
So the piping in that pic does have more bends than most layouts but whether or not the lenght of piping used is more or less is difficult to guess. I suspect when you add it all up there isn't much difference (length wise) between the 3 setups.
I have no idea what the laws of physics say about pushing air around a 180° bend as opposed to a 90° one but surely the sum of all the bends must have some bearing on velocity of the air and lag/throttle response etc.
Every bend causes a slight pressure drop, additional length/volume detrimentally affects throttle response (NOT the same as lag), so yes that would be worse off. But by how much? Well not a lot, i think it looks quite neat and it gets extra point for being different.
Gives you more torque if you can queue up the air in a nice straight line.
Why?
IMO the only real benefit of not having a bend in before the TB is to prevent any unusual flow patterns from messing with the distribution of air to each cylinder, and I tend to think this would be a small, if not negligible effect in the majority of situations. If you wanted to be pedantic, the safest bet would be to stick with the factory piping, as that's the only configuration thats had any real R&D.
I also don't understand your comments about air "backing up" at the throttle plate.
Don’t worry dude just stating an opinion, I don’t really care to discuss this boring topic in great detail. The standard setup is better I believe and it has a nice straight run off the throttle. If you like the windy piping in the Kermit car then cool, the difference it makes is insignificant anyway.
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
