If you wanted to keep the turbo looking standard for defect purposes,
would using a high flowed turbo be an option?
What sort of power figures would you be able to pull from a standard RB20DET turbo thats be high flowed?
Does high flowing mean changing to steel wheels or increase the size of the wheels, or both?
https://www.sau.com.au/forums/topic/90576-high-flowing-a-rb20det-turbo/
IMO, I wouldn't bother. Go to something like a GCG HiFlow RB25DET turbo, will still look quite stock and have substantially better power prospects.
I could be wrong, but I suspect thats what people will say.
The other thing is that low mount upgrades that fit your stock manifold would let you keep your factory heatshielding (mostly) which would look quite stock too....
I'm sure the RB25 turbo will bolt up to a Rb20.
The GCG Hi-flow is inbetween a stage 1 and stage 2 hi-flow.
What they do is replace the ball bearings with new and fit bigger compressor & turbine wheels. They are good for about 450hp or 230rwkw - 250rwkw depending on the supporting mods.
If you want to keep the stock appearance this would be the way to go.
What would something with these specs run like on a RB20:-
High flowed RB20 turbo, it is running a larger steel exhaust wheel (wheel is larger than a stock RB25 ceramic wheel). The compressor is standard. It is running a plain-bearing centre (not the BB centre of a RB20DET). Housings have been machined to improve flow characteristics.
If your looking at making 200rwkw it's perfectly capable of being made on a standard turbo from what I've heard.
Things you can try before spending big $$ on a upgraded turbo is -
FMIC $1100 - $1400
Apexi PFC - $960 (Group buy)
Pod Filter or Upgrade Panel Filter - $100
Bleed Valve @ 12psi - $100
Full Exhaust (Hi-Flow Cat) - $1000
With that you should reach. I put out 163.7rwkws with only boost raised to 12psi, the tuner said if I had PFC + Full Exhaust + FMIC I could easily hit 200rwkw. I don't think an RB20 would be that much behind.
FMIC $1100 - $1400
Show me where your getting an RB20 pfc for under $1k and I'll buy it.
I think with a standard turbo 200rwkw will be destructive push. Just get an r33 or r34 turbo, the cost difference your going to be damn close to your wanted power, and when the turbo does die you got something a bit bigger to hiflow.
FMIC $1100 - $1400
FMIC $600
Apexi Power FC Ap Engineered $1050 from me :(
Pod filter - wouldn't really bother
Bleed valve - $35 from turbotech
http://www.skylinesaustralia.com/forums/in...showtopic=73375
Exhaust - $400+ depending on what ya get
WIth that you should be around the 170rwk's as thats what my other car is running with stock turbo at 12psi :)
Cheers B
I wouldn't bother with a cheap highflow of the rb20 turbo.
Slap a rb25 turbo on it and make near the same power with much less lag. OR as Mr. Bass suggested, grab a R34 turbo, they are the larger of the turbo's bolted on the side of the RB25 and tend to make a little more power.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
