Hi guys
Just after exactly what is needed to be wired up for my Rb20det to run in my 87 silo.
I have tried to wire it up from another forums instructions but can't get it to kick over. There is no injector pulse.
Any pictures of the wiring would also be greatly appreciated.
It's just frusterating me, it's there but i can't drive it :blink:
Thanks guys
https://www.sau.com.au/forums/topic/90589-rb20det-into-r31-wiring-problem/
The first thing you want to check is that the CAS, injectors, coils and ecu are getting power.
You should be able to hear the eccs and ignition relay flicking in and out when you turn the key to ignition and back off. The ecu should also be lighting up the red LED on the botton edge. If you cant see the light or hear the relays then you need to re trace the power feeds.
The temp gauge signal is just a single wire plug in the inlet manifold casting just above the thermostat at the front. You need to wire that directly to your gauge. It would have been in the original under dash plugs on the r31 dash loom and in the r32 engine loom
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
