My R34 GTR started doing the same thing after I had it dynoed in 4wd. The workshop didn't know what they were doing & I hadn't had the car that long. Nothing I could really do, but they f*@ked the clutches in the transfer case.
I take my GTR to Racepace (any one will tell you Ben is the guru) and Ben diagnosed the problem accurately.
Replace the clutches after you do the air bleed in HPI.
A note to all GTR owners.
DO NOT HAVE YOUR CAR DYNOED ON A 4WD DYNO.
Anyone who knows what they are doing will drop the front driveshaft.
BEWARE THIS COST ME $1200. (Cheaper on a R34 as the clutches are replaced independant of the gearbox)
Tell me whats so special about nissans ATF for ATTESA?
yug: On a 4wd dyno its only running the transfer clutchs for a few seconds, not much different to giving it a bit of stick on the road, the clutches engage?
thanks yug_r34 for ur info...
i just drove it again and drives pritty much like me mates 180sx,drifting all over the shop...also got on the dirt and just rev slightly and the gauge moved almost instanlly,so i gather it may be the transfer case.....will it hurt my car by drivinbg it how it is or should i get a new box or case asap
bump will b driving car to newcastle this weekend,wont hurt me car anymore than it has already aye??????also will bleed system b4 i go so fingers crossed a shit load of air will come out of the bleed valve and it not be the transfer case,so wish me luck
gday mate, I reckon you have got really badly worn clutches in the transfer case.
Air in the lines, busted sensors, low fluid, all these things will normally turn on the warning light on the dash and flash a code on the computer under the parcel shelf in the boot.
In this case it sounds like the transfer case knows what it should do, but it can't. Another thing wierd as it sounds could be ferni's suggestion - maybe the front drive shaft is missing? have a look underneath.
Either way there is almost no chance you will hurt anything with a 32 due to front torque problems
no worries ill bleed the system next week if i can get a hold of me mates hoist...
i think u maybe right duncan the transfer case maybe buggered....
worth fixing or just better to buy 2nd hand box u think
definately get yours rebuilt. There is every chance a second hand one will be from another 32 and ready to die too.
Reasons to get yours rebuilt....there are a couple of hours labour involved whether you replace or rebuild so its not cheap anyway. you know it will be in top condition, and while its open they can put extra clutch plates in the increase the front torque which is desperately needed in a 32
And no I don't know where to get it done :(
or give CRD a call and ask who they use. I think you will find everyone sends it out to an auto transmission specialist since they are pretty much an auto as far as the clutch plates go. But I don't know who knows what they are doing with one :D
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
