Biggest Wheels For R32
hey all, got 17x9.5"s for the back and 17x8.5"s for the front
will they fit R32?? i know they fit R33
all help appreciated
hi
i am running 17 x 10s all round on my r32 gtr and have no problems
have 255/40 rubber all round
My mate has an R32 GTS (soon to have a VH45 in it), but anyways he's running 9' rears with 8' front and with 245 rubber on the back, the rear tyres were getting rubbed out a bit just on the sidewall, with lipping it's now fine. So that'd be a should/probably from me, and also obviously the R32GTR guards are able to accomodate larger rims and rubber so GTR experience is irrelevent in your situation.
Cheers
Gotta remember tho mate...its not all about the width. Usually means that different width/offset combinations can b used and thus diferent charecteristics. ie. alot less offet (+12 for example) may mean that u will get scrubbing against ur arch while the same wheel in a +32 mite b perfect
i was using any numbers just to use an example.
If ur car is lowered and ur running those wheels they'll b sticking slightly out of the guards i believe...best to fit them and see how they go coz its not only body clearance but suspension, brake clearance u gotta worry about
Baz will vouch for this.
My R32 Gts-t, has 17"x10" on the rear and 9" on the front.
No rubbing, and the car is lowered as far as it will go with its
TEIN Racing suspension.
I’m certain you will have no worries.
Edited by re2
Can you please email pics and offset details to [email protected]
I need traction.. :D
Greg
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
