  • Replies 58
Posted Images
Do you have a fuel pressure reg?
How do stock injectors induce the 'lag'? Would be good to know what duty cycle your hitting - you don't have a h/c?
252rwkw sounds pretty close to what i made on stock turbos. Do you have adjustable cam gears?
No i dont have a regulator or hand controller unfortunately.. the inducing lag bit didn't come out quite right. My tuner said basically if there could be more fuel put in down low it'd spool it up quicker, but the stock injectors are pretty close to their limit and pushing them closer would be living dangerously. So, if I did the fuelling upgrades im sure we could get it spooling quicker, how much quicker I got no idea.
Yeh got HKS cam gears..don't think they were adjusted with latest tune for new turbo's.
I can't see how you can be at 100% duty cycle down low? that doesn't seem right. i can see them being at 100% at 8000rpm, but not at 3000 to 4000? I could be wrong though.
Exactly my thoughts. I don't know much but i would assume at 4000rpm, they only have to fire half as much as they would at 8000rpm. From what i have seen, injectors usually max out up the top of the rev range.
We need someone more knowledgable to answer :angry:
Fuel pressure reg should help get a little more out of the injectors. Only a couple of hundred bucks.
the gearbox can handle more power than that. just don't abuse the gearbox and don't put a solid centre clutch in it, i know from expereince :O
i know that gtr gear can handle more power....but jono think that his gear box is stuff...cant run....
Jerry: any idea what the difference would be between your setup and GTR032? Just tune or something else?
Well , i have a 34 engine , almost new , tune of course is different well under 12-1 at 11.5-1 , i wont run 12's on a stock engine .
I dont have cam gears or dump pipes but the 34's have s/steel dumps not cast and i have 550 injectors , the other thing mine will only make 240 awkw .
I'm not after big power in my setup , i just want a quick street car not big dyno numbers .
I did 11.8 @ 118 mph a couple of weeks ago with a bit left in her still , i'm happy the way she goes as i have plenty response , almost like a stocker and 34's are more responsive that 33's and 32's (if all 3 are stockers ) .
Actualy if i had steel wheel turbos i wouldn't bother with the gtss's , thats the reason i tried to buy an NUR M-SPEC , maybe next time !
Gtss's are not cheap but in my opinion ideal for a stock engine but stock injectors would be right on the limit , thats why i went for the Nismo 550's ( again not cheap , you can get sard much cheaper ).
Can injectors have anything to do with lag like GTR032 mentioned earlier in this thread?
Why are 34's more responsive than 33's and 32's stock?
No they shouldn't have ,as they supply all the fuel needed, i dont know if the cams are the same in the 3 cars , so that maybe one reason , different turbos is another and who knows they may run more timing as well as better dump pipes . Ports and valves i think are the same but i never had a 34 head off the car so i cant say for sure , i'm only going on what others have told me . I know from experiance they run more boost .
Are you going the gtss road Andrew ?
All you need is the turbos ,dumps, power f/c, ebc and 550 injectors , as long as you have a good donk ( do a compression and a leakdown test to confirm ) and you will have a much quicker car and almost as responsive as it is now .
GTR032: how is your car going anyway?
I had the pleasure of being a passenger in it for 1.5hrs the other night and I must say that it drives very well. It has better response/power under 3000rpm than my R33 GTS-t did with the stock turbo B)
Yep turbos and pfc are on thier way.
Car's going pretty good. No dramas since new tune :P
Just got to fix up an ongoing tailshaft type vibration. After that will take it down to WSID to get a time.
...Deadset? Thats pretty damn cool. I sure as hell dont want to go for a ride in Fernis car when its finished...aint enough Prozac getting around
there there Troy... Just put on that GTR bonnet etc, and get three gauges for the centre console and sit in the driveway making car noises. then you will feel like a GTR owner. :)
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
