Hi All,
I have a set of R33 GTR rotors waiting to go into my S15 with callipers to match but im a little hesitant as im not sure if there is a difference in Left and Right rotors.
I cant seem to find a visible difference, i.e the casting looks identical, it doesn’t seem to show a directional bias in the cooling veins, from this I have assumed that there is no difference between L & R.
Could someone confirm if this is the case???
Cheers
Marco
https://www.sau.com.au/forums/topic/90696-standard-gtr-rotors/
Std GTR32 rotors are curved vane, so are left and right.
I can only then assume that std GTR33 rotors would also be curved vane, and should be mounted left and right specific.
I'm only guessing, so I would check with someone who knows for sure...
I'm sure someone on here will know
don't know if that helps you at all.
DAM... i thought i had it sorted.. the part numbers are the same though might not be DBA's as on the internal they don’t have varied casting like the PAW ones.. hmmm..
I take the general consensus to be if the rotor is non-bias and symmetrical it will not effect one side or the other....
they actually look like DBA kangaroo paw rotors to me. in which case they usually have an L or R sticker and part number suffix.
