Ok here is the problem, i have no power above 2500 revs, it will go up to here fine then once it hits that point then it will just stop like it is not getting any pertol. When it is doing this problem it will idle at about 1500 - 2000 revs instead of 500 - 1000 revs. Now this does not happen every time i drive the car and there is no common pattern that makes it do it.
I have had the car services and the mechanics cleaned out the injectors, put a new fuel pump in, checked the fuel pump, changed spark plugs and a heap of other things and could not find anything that is making the problem.
The car is a r32 gts-t (rb20det) with a 3" exausht from turbo and a 5" tip, and a HKS pod filter. Any help would be great as it is making the car so hard to drive.
https://www.sau.com.au/forums/topic/90708-annoying-problem/
The 5" tip is your problem - too much bling for a R32 GTSt.
Seriously, though, if you searched these forums you would have been able to uncover that fact that a dead or dying AFM (Air Flow Meter) will set the ECU into limp-home mode and will not permit the engine to rev at more than 2500.
https://www.sau.com.au/forums/topic/90708-annoying-problem/#findComment-1633914
my bad its only 4"
Hehe, in that case maybe you need it upgraded to 5" ;)
Seriously though, it's almost certainly an AFM problem. I've had a similar thing happen when I accidentally yoinked out my S-AFC awhile ago, which among other things, severs the signal wire from the AFM. I also recently have my AFM die a half-arsed death, which resulted in the car being unable to idle, although I could get above 2500rpm in that case by keeping the throttle open.
https://www.sau.com.au/forums/topic/90708-annoying-problem/#findComment-1634188
Why not just run an ecu diagnostic rather than playing guessing games to see what your problem is? That will give you a definative answer to if your car has a bung AFM. Idling problems can be caused by an excessive amount of things just to name a few dirty/in-op/incorrectly set AAC valve, incorrectly set idle via throttle plate, carbon buildup on throttle plate, AFM problems, air regulator and the list goes on....
Do a seach and that should fix your problem.
https://www.sau.com.au/forums/topic/90708-annoying-problem/#findComment-1634265
Second hand should be around $150 or less. Try Ebay, you might be lucky. If not then JustJap should have one and they deliver too. Test it before you go and buy one first, it could just be a bad connector or something. See if you can borrow a known working one from someone and hook it up.
https://www.sau.com.au/forums/topic/90708-annoying-problem/#findComment-1634395
Going to the mechanics tomorrow to have it hooked up to a diagnostics computer. Hopefully it is just a bad connector as this will take away money from my FMIC ;)
What would cause it to go into limp-home mode, as it doesnt always have the problem?
https://www.sau.com.au/forums/topic/90708-annoying-problem/#findComment-1634419
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
