If u hav the spare cash, Blitz i-color, first full color boost controller on the market, it has combined the Blitz Power ID with the Blitz SBC and given it a full color interface display unit...mind-blowing display, if u want something that holds boost well, GReddy Profec B Spec2 or Profec E-01. I've heard the turbosmart ones hold boost well too. The avc-r is not bad, but definitely not the best in holding boost. However, it's easy to use and pretty comprehensive.
BLITZ SBC I-D III
Best Value for Money IMO....
Probably the best on the market next to the New I- Colour but there is around a $500 Price Differance
SBC I-D III -- $ Around 600 Brand New
I-Colour -- $ Around 1K Brand New but has shitloads more Features....
Obviously almost everyone is going to recomend the EBC that they have in their own cars...so I'll do the same :(
I've got a GReddy Profec B Spec II and it does the job for me. It might not have all the snazzy displays of some other EBC's, but it does have most of the functionality that you'll ever need (3 boost settings, gain function, peak hold display, boost warning etc). And most importantly, it holds boost fairly constant through the rev range.
Good value for money :)
Thanks. I tried a search but it wasn't going to be quick...
38 Pages on EBC's :\
I'm leaning towards the boost controller kit for the PFC as it's cheap and has pretty much the same functionality as the AVC-R.
I might add the thing I liked about the Profec B II is the add-on feature you can get with that boost button thingo for the steering wheels :)
I'm going to be using the Turbosmart E-Boost 2 - Apparently, features +++ and controls the extarnal gates NO Problem... So, reviews and peoples experience will be the determining factor I think.... Good Luck in choosing... there is heaps out there.
I second the Jaycar. Its the cheapest and the best.
Make sure you get one that uses the solenoid to completely block off the air flow to the actuator, they work the best in terms of reducing wastegate creep to the lowest possible.
At the moment I have one of those Turbosmart bleed valves..
Would it be an advantage if I got myself an Electronic type boost controller?
If so which would be most suitable Apexi AVC-R, Greddy Profec B II?
I have an Apexi PFC so I was thinking the Apexi AVC-R..
Depends on how much boost you eventually want to run. Above about 1.2 bar you probably should go for a dual solenoid setup - in which case I would recommend the Blitz ID III.
Below that a single solenoid Blitz or an Apexi will do a good job.
Best prices are either from Nengun or Greenline etc.
Gentalman i have an E boost 2 fitted to my r33 with small mods
ok let me say when it was installed it was set too high and i did not like it
but an e mail to turbo smart and no s$% i had a phone call less than 5mins later asking wat was wrong
he told me how to set it
now it is the BEST thing i own, no really it is a boost gauge as well
i can do minor adjustment from my cabin and it holds boost well,
very well + dont need to spend $$$$$ on gauge and they are AUSTRALIAN THEY ARE THE BEST END OF STORY
mine cost me $915 installed but i dont think its needs a dyno straight away it has a 1 to 100 setting 30 is 10psi 40 is 14 psi and so on but only on the 40 psi model.
I am on 30 now 10psi but i can stress enough without taking you for a wrap how user friendly they are
ps i dont work for turbo smart but when you find a good product you tell everyone i think + we should have a thread about good mods so we all no wat is good to buy
How much for the Eboost and how much for a jaycar kit?
I just paid $745 (E-Boost 2)and I'll be doing a self install. So, we'll see how it goes... The Jaycar kit, all up plus an hour or 2 of your time cost about <$150 - although, does it have a "BLING" display like the E-Boost (2)?? :angry:
Also, you'll need a boost gauge and that can be anywhere from $80-$$$$$.
Edited by QUIKBLADE
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
