Hey guys my R32 GTS4 is being a bit annoing recently, it's cutting out at low rpm at low speed or sitting at idle. Thing is it only does it sometime, usually when it's cold. Except it's not really stalling as such, before my connections to my AFM were a bit suss but ive rectified that problem (although it has somewhat come back, occasionally surging and cutting power - ie AFM not reading etc properly) but i'm about to look at this now. I'm hopeful it's just the AFM, but if anyone has experienced similar problems I would love to hear from you, even if it's to put my mind at ease. (enough to worry about let alone a very annoying cutting out habbit my car seems to have adopted). Thanks in advance
Cheers,
Rhys ;)
I had a similar symptoms and it turned out to be water in the intake from when i drove through a really huge puddle during a storm. went away... eventually
Hey mate would you be able to say where exactly in the intake, i did notice that i had a bit too much oil on my K&N panel filter when i gave it a recharge and there was some residual oil in the actual air box which might be similar to what you have said.
Cheers
the mechanic said that the water had been sucked straight through my pod filter. im lucky it didnt stuff the whole engine because water doesnt compress that well lol
Haha yeah water isn't the greatest thing for your engine. Cheers for the comment. Have a top one.
Rhys
Found a post suggesting it could be the grounding wire to the fuel pump so i'l give that a go, sorry to regurgitate the same query guys. But will be back here if fixing the grounding wire idea is incapable of rectifying the problem.
Cheers
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 馃槅
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
