Group Buy - Dba Slotted Rotors - From $195 Each.
Heres a group buy for DBA 4000 series slotted rotors.
If I can move 10 sets (40 rotors) then we get the good price ;)
(Note - pairs can be purchased instead of a full set.)
INFO:
All are the 4000 series slotted only.
R32 GTST (RB20DET)
Front (280mmx30mm) - $195.00each
Rear (297mmx18mm) - $195.00each
R33 GTST (RB25DET)
Front (296mmx30mm) - $200.00each
R34 GTT (RB25DET)
Front (310mmx30mm) - $200.00each
R32 GTR (RB26DET) non v-spec brembo
Front (296mmx32mm) - $200.00 each
R32 GTR (RB26DETT) V-spec brembo
Front (324mmx30mm) - $220.00each
Rear (300mmx22mm) - $195.00each
R33 & R34 GTR run the same brakes as the R32 GTR v-spec brembo.
Also Available :
R31 Skyline
Front slotted (non 4000 series) $150.00each
Rear slotted (non 4000 series) $150.00each
350Z (normal brakes)
Front (296mm x 24mm) - $195.00each
Rear (292mm x 16mm) - $205.00each
350Z (brembo brakes)
Front (4 piston 324mm x 30mm) - $220.00each
Rear (2 piston 322mm x 22mm) - $220.00each
More info at the DBA website
SHIPPING:
Postage for 2 rotors direct is $22
Postage for 4 rotors direct is $33
For Melb - Syd - Adel - Canberra - Bris metro (country extra $5)
Postage to Perth - Darwin - ACT - Alice, is a flate rate $44
The rotors are fairly heavy so all will be sent via courier.
FINISH DATE :
Ends - 25th Oct 05.
Payments due - 30th Oct 05.
Im getting 2 full sets (for me and a mate) so we only need to move 8 sets (16 pairs).
1/ gR33ddy - R33 GTST (2xF & 2xR) - PAID - sent.
2/ gR33ddy - R33 GTST (2xF & 2xR) - PAID - sent.
3/ mass_iv - R33 GTST (2xF) - PAID - PAID - sent.
4/ YLD-CHLD - R32 GTR (2xF & 2xR) - PAID - sent.
5/ SirSkyline - R33 GTST (2xF) - PAID - sent.
6/ Pretender - R33 GTST (2xF & 2xR) - PAID - sent.
7/ nisr32 - R32 GTST (2xF & 2xR) - ??????????????
8/ gR33ddy - R32 GTST (2xF) - PAID - sent
9/ private buyer - R33 GTST (2xF) - PAID - sent.
10/ Chicko's GTR32 - R32 GTR (2xF) - PAID - sent.
11/ shif_tea - R33 GTST (2xF) - PAID - sent.
12/ gtrGhosTDoGG11 - R33 GTST (2xF) - ??????????
  • Replies 97
are these the kangaroo paw ones????
if so and for $200 each ill take a set of front discs, not sure if its r32GTR or r33GTST yet....
Yep, they are the kangaroo paw ones.
Link - 4000 series spec sheet
I'll include you in the list of buyers - you can confirm which type you require at any time.
oh and Paul when do you think the due date for payment will be?
Payment can be made at anytime.
A couple of guys will be paying in about a week which is ok.
PM me when you are ready and I'll forward payment details.
Once your payment has been received your rotors will be sent.
Cheers :(
hey i would also like to know the price without group buy on r34 gtt front set
cheers,
R34 GTT (RB25DET)
Guest
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
    • Hoping they release an R34 getrag pull type.
    • You need the bottom spacers, to make it a 3/4 height injector. https://www.efihardware.com/products/3040/injector-adapter-lower-for-extended-nose-injectors   And you'll need to buy the right injector bosses, these "might" fit. You'll need to measure it up. https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/
    • Unless there's something particular about the Greddy manifold's injector holes that I'm not aware of, those injetcors look to be totally wrong. They would absolutely want to be spaced up to get those long snouts out of the runner. Which, I think, is not usually the way that that problem is solved. I think the problem is solved by using the correct injectors, which would be much more like what Andrew posted.
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
