b4 any one starts yes i have searched and read, and called performance places and........had a pull in the process
My dilemma, I have a 89 r32 GTR pretty stock, just spun the clutch now slips almost all the time no new news there. Im looking at pumping around 300kwaw ish, and have been recommended a few different clutches, my car is a daily driver but also I drive my cars hard……..”ice performance”, and “race pace” have recommended a similar set up a excedy heavy duty cushion button clutch “10 puck was mentioned” and have told me that should be great for the power im after, not slip, take launches, and last for quite a while.
But other sources have told me as soon as I start to approach the 300kw mark it will spin….and have recommended a 3 or 4 puck excedy….keeping that in mind I have been told a 4 puck may only last me 2-3months……..
You can see that im getting nowhere fast each view contradicts the other…..and vice versa
I’m hoping to go single plate, at the moment any way
Just hoping some one can help verify whats been said just to make it a little more simple
1. I plan to run 300kwaw give or take
2. Don’t want clutch to spin
3. Want it to last
4. Want single plate
5. will be doing 6k launches
6. Don’t want to spend more then 2k
What will meet my criteria ??
https://www.sau.com.au/forums/topic/90766-345-puckcushion-button-10puck/
call up xtreme clutch... they have MANY clutches to suit you... or try www.xtremeclutch.com.au
I've heard they have some great 9 puck clutches (ceramic), which have very nice power handling and aren't much different to stock to drive on! :)
But generally, the less the number of pucks, and the higher rated the pressure plate, the harder it will be to drive.
Less pucks = pickup is ALOT more sudden, as you're applying all the clamping force over a much smaller area... aka. jerky! can't really ride them as much - not that you should ride your clutch... I personally wouldn't go for a 3 puck clutch... lowest is probably 5 puck i'd go, then i'd go to a twin plate or similar (for street use).
The higher rated the pressure plate, the stronger the clamping force. While this sounds good, it will also be alot "heavier" on your leg... which again, affects driveability (makes it harder to "modulate" the clutch).
Nismo Coppermix twin plate is around $2k from nengun. Will take that much power and drives like a stock car. There are at least two GTRs I know of running this clutch on here and they both say its fantastic.
Other than that - Jim Berry in QLD would be able to build you a clutch to suit your application. Search the forums for his name.
Nismo coppermix twin plate , fantastic clutch and it feels almost like a stocker , especialy if you use the bigger nismo slave with it .
It comes with a lighter flywheel a new release bearing and new flywheel bolts .
I dont know if you can get a push nismo twin clutch to suit your 99 32 , check it out on the Nismo website .
3. Want it to last
Thanks  :O
You're going to get different opinions here as well.
One thing is for sure. Do not get a solid centre clutch.
My opinion: I have a Jim berry clutch which cost around the $1000 mark, i drive my car daily and take it to the track, seems to be holding up well and is very easy to drive. I would recommend one of these, or get Ben from Racepace to get you one of the single plates he uses. also around the same price. Frank runs over 350rwkw and used one of the clutches Ben got for 2-3 years. and he doesn' go easy on his car :)
sewid is on the money go the Nismo Coppermix or get in contact with Jim Berry (Race Clutch) on (07) 3847 9999. Jim is very renown for making clutches that can handle abuse and last.
Over the years I have used so many clutches it is ridiculous. I was spending at least $1000 a clutch and they were running out faster than my fuel. I finally spoke to some guys in the know and they sent me down to "BGT Brakes" in Dandy. Anyway $400 later they had built me a 4 button ceramic clutch that they recon will last at least 3 years of hard driving. So far I have given it a very hard time and have also taken it to a few track days, feels as good as the day I got it.
I installed this clutch myself so all up it cost me just $400.
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
