b4 any one starts yes i have searched and read, and called performance places and........had a pull in the process
My dilemma, I have a 89 r32 GTR pretty stock, just spun the clutch now slips almost all the time no new news there. Im looking at pumping around 300kwaw ish, and have been recommended a few different clutches, my car is a daily driver but also I drive my cars hard……..”ice performance”, and “race pace” have recommended a similar set up a excedy heavy duty cushion button clutch “10 puck was mentioned” and have told me that should be great for the power im after, not slip, take launches, and last for quite a while.
But other sources have told me as soon as I start to approach the 300kw mark it will spin….and have recommended a 3 or 4 puck excedy….keeping that in mind I have been told a 4 puck may only last me 2-3months……..
You can see that im getting nowhere fast each view contradicts the other…..and vice versa
I’m hoping to go single plate, at the moment any way
Just hoping some one can help verify whats been said just to make it a little more simple
1. I plan to run 300kwaw give or take
2. Don’t want clutch to spin
3. Want it to last
4. Want single plate
5. will be doing 6k launches
6. Don’t want to spend more then 2k
What will meet my criteria ??
https://www.sau.com.au/forums/topic/90766-345-puckcushion-button-10puck/
call up xtreme clutch... they have MANY clutches to suit you... or try www.xtremeclutch.com.au
I've heard they have some great 9 puck clutches (ceramic), which have very nice power handling and aren't much different to stock to drive on! :)
But generally, the less the number of pucks, and the higher rated the pressure plate, the harder it will be to drive.
Less pucks = pickup is ALOT more sudden, as you're applying all the clamping force over a much smaller area... aka. jerky! can't really ride them as much - not that you should ride your clutch... I personally wouldn't go for a 3 puck clutch... lowest is probably 5 puck i'd go, then i'd go to a twin plate or similar (for street use).
The higher rated the pressure plate, the stronger the clamping force. While this sounds good, it will also be alot "heavier" on your leg... which again, affects driveability (makes it harder to "modulate" the clutch).
Nismo Coppermix twin plate is around $2k from nengun. Will take that much power and drives like a stock car. There are at least two GTRs I know of running this clutch on here and they both say its fantastic.
Other than that - Jim Berry in QLD would be able to build you a clutch to suit your application. Search the forums for his name.
Nismo coppermix twin plate , fantastic clutch and it feels almost like a stocker , especialy if you use the bigger nismo slave with it .
It comes with a lighter flywheel a new release bearing and new flywheel bolts .
I dont know if you can get a push nismo twin clutch to suit your 99 32 , check it out on the Nismo website .
3. Want it to last
Thanks  :O
You're going to get different opinions here as well.
One thing is for sure. Do not get a solid centre clutch.
My opinion: I have a Jim berry clutch which cost around the $1000 mark, i drive my car daily and take it to the track, seems to be holding up well and is very easy to drive. I would recommend one of these, or get Ben from Racepace to get you one of the single plates he uses. also around the same price. Frank runs over 350rwkw and used one of the clutches Ben got for 2-3 years. and he doesn' go easy on his car :)
sewid is on the money go the Nismo Coppermix or get in contact with Jim Berry (Race Clutch) on (07) 3847 9999. Jim is very renown for making clutches that can handle abuse and last.
Over the years I have used so many clutches it is ridiculous. I was spending at least $1000 a clutch and they were running out faster than my fuel. I finally spoke to some guys in the know and they sent me down to "BGT Brakes" in Dandy. Anyway $400 later they had built me a 4 button ceramic clutch that they recon will last at least 3 years of hard driving. So far I have given it a very hard time and have also taken it to a few track days, feels as good as the day I got it.
I installed this clutch myself so all up it cost me just $400.
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
