b4 any one starts yes i have searched and read, and called performance places and........had a pull in the process
My dilemma, I have a 89 r32 GTR pretty stock, just spun the clutch now slips almost all the time no new news there. Im looking at pumping around 300kwaw ish, and have been recommended a few different clutches, my car is a daily driver but also I drive my cars hard……..”ice performance”, and “race pace” have recommended a similar set up a excedy heavy duty cushion button clutch “10 puck was mentioned” and have told me that should be great for the power im after, not slip, take launches, and last for quite a while.
But other sources have told me as soon as I start to approach the 300kw mark it will spin….and have recommended a 3 or 4 puck excedy….keeping that in mind I have been told a 4 puck may only last me 2-3months……..
You can see that im getting nowhere fast each view contradicts the other…..and vice versa
I’m hoping to go single plate, at the moment any way
Just hoping some one can help verify whats been said just to make it a little more simple
1. I plan to run 300kwaw give or take
2. Don’t want clutch to spin
3. Want it to last
4. Want single plate
5. will be doing 6k launches
6. Don’t want to spend more then 2k
What will meet my criteria ??
https://www.sau.com.au/forums/topic/90766-345-puckcushion-button-10puck/
call up xtreme clutch... they have MANY clutches to suit you... or try www.xtremeclutch.com.au
I've heard they have some great 9 puck clutches (ceramic), which have very nice power handling and aren't much different to stock to drive on! :)
But generally, the less the number of pucks, and the higher rated the pressure plate, the harder it will be to drive.
Less pucks = pickup is ALOT more sudden, as you're applying all the clamping force over a much smaller area... aka. jerky! can't really ride them as much - not that you should ride your clutch... I personally wouldn't go for a 3 puck clutch... lowest is probably 5 puck i'd go, then i'd go to a twin plate or similar (for street use).
The higher rated the pressure plate, the stronger the clamping force. While this sounds good, it will also be alot "heavier" on your leg... which again, affects driveability (makes it harder to "modulate" the clutch).
Nismo Coppermix twin plate is around $2k from nengun. Will take that much power and drives like a stock car. There are at least two GTRs I know of running this clutch on here and they both say its fantastic.
Other than that - Jim Berry in QLD would be able to build you a clutch to suit your application. Search the forums for his name.
Nismo coppermix twin plate , fantastic clutch and it feels almost like a stocker , especialy if you use the bigger nismo slave with it .
It comes with a lighter flywheel a new release bearing and new flywheel bolts .
I dont know if you can get a push nismo twin clutch to suit your 99 32 , check it out on the Nismo website .
3. Want it to last
Thanks  :O
You're going to get different opinions here as well.
One thing is for sure. Do not get a solid centre clutch.
My opinion: I have a Jim berry clutch which cost around the $1000 mark, i drive my car daily and take it to the track, seems to be holding up well and is very easy to drive. I would recommend one of these, or get Ben from Racepace to get you one of the single plates he uses. also around the same price. Frank runs over 350rwkw and used one of the clutches Ben got for 2-3 years. and he doesn' go easy on his car :)
sewid is on the money go the Nismo Coppermix or get in contact with Jim Berry (Race Clutch) on (07) 3847 9999. Jim is very renown for making clutches that can handle abuse and last.
Over the years I have used so many clutches it is ridiculous. I was spending at least $1000 a clutch and they were running out faster than my fuel. I finally spoke to some guys in the know and they sent me down to "BGT Brakes" in Dandy. Anyway $400 later they had built me a 4 button ceramic clutch that they recon will last at least 3 years of hard driving. So far I have given it a very hard time and have also taken it to a few track days, feels as good as the day I got it.
I installed this clutch myself so all up it cost me just $400.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
