  • Replies 50
Flames popping out the exhaust is most likely due to an external wastegate that is dumped back into the exhaust system. You will need to remove the cat for this though.
Another option is to run rotational idle, this will give you a small fire popping out of the exhaust, you are unlikely to get any huge flames from the back unless you do something stupid, which I don't recommend.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9077-exhaust-flames/#findComment-135837
Paul, give me your advice. I need a turbo, new manifold or keep it standard. Would like an external wastegate but the money to make a manifold is quite heavy. Unless you know someone??
Or could get some sort of drawing plan for some, cause i could quite easily do all the fabricating but I need a plan.
https://www.sau.com.au/forums/topic/9077-exhaust-flames/#findComment-135888
Hicks,
the best turbos are all external wastegate design, but these are for high horsepower. If you just want good power then you can go for a GT2835 (internal wastegate) , which will give you lots of power without the lag. I would still recommend a custom exhaust manifold, the original is very poorly designed.
If you a good with mild steel welding then I could get you a jig, which is a template to build manifolds, this would make it easy for you to build your own.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9077-exhaust-flames/#findComment-135904
Removing cat is highly illegal and will lead to $10,000 (or there abouts, could have been $5,000, can't remember) fines if caught... Flamage is from anti-lag, not rotational idle as discussed in rotational idle thread...
In the old days an extra injector used to be fitted to the exhaust manifold and fired when anti-lag was needed... Now-a-days the ECU controls it all...
https://www.sau.com.au/forums/topic/9077-exhaust-flames/#findComment-135930
The computer measures the airflow at the beginning of the intake tract (assuming you're using a MAF system) and injects fuel accordingly. So when you shift and let off the gas, your turbo is still spinning and the excess air is vented through the blow-off valve. However the computer doesn't know that that air isn't going into the combustion chamber, so while the blow-off valve is going the mixture in the combustion chamber is very rich, thus letting a lot of unburned fuel into the exhaust, where it gets ignited by the hot turbine wheel. Hence flames on shifting.
J
https://www.sau.com.au/forums/topic/9077-exhaust-flames/#findComment-135952
Originally posted by GTS-t VSPEC
Hicks,
See'ya:burnout:
I could weld it up piece of piss, A monkey can weld mild steel.
Where would you get a jig from? Would they let you have one?
https://www.sau.com.au/forums/topic/9077-exhaust-flames/#findComment-136097
Originally posted by MIKGTR
Too easy in my car
Step one: change fuel map to +30% rich
step Two: lower rev limit to 4000
step three: flat change at 3900rpm
result: fireball + mushroom cloud
scares the shyt out of tailgaters & pedestrians:D
is that through a safc, or what
https://www.sau.com.au/forums/topic/9077-exhaust-flames/#findComment-136185
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
