Recent service performed with all new oils/filters etc and new plugs, new battery fitted last month.
Non smokers car, car has always been garaged and never been in -any- accidents, no panels ever resprayed.
I have spent over $20,000 in the last year modifying this car, it is perfectly streetable only 3x as potent when you open up the throttle, street driving the car drives no different to a standard gtr.
Just spent $1500 putting on standard turbos on the car and getting it all retuned. Bolt on a pair of ball bearing turbos and you will have close to 300kw at all 4 without a hassle, everything else you need is already on the car. Car just made 256kw at all 4 on 14psi (dyno sheet to prove) approx 280rwkw as is now. Keep in mind a standard gtr has around 170kw.
Some of the current mods include:
100mm intercooler
3 exhaust system from turbos back
Single plate brass button clutch
Apexi PFC fully tuned
K&N pod filters
Boost controller
HKS adjustable cam gears
700CC injectors + 700hp Intank fuel pump
+ plenty other bits and pieces.
Any professional inspections welcome. As always serious buyers only thanks. Selling as im downgrading to spend some money on the house.
Price negotiable within reason. Email bjrose at optusnet dot net.au
or
Phone 0413 382 678 between 4-8pm weekdays, normal times weekends, dont bother sms'ing me.
View the car sales ad here: http://carsales.com.au/pls/carsales/!c...rch_distance=25
Edited by MidnightGTR
https://www.sau.com.au/forums/topic/90771-1995-r33-gtr/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
