Please submit a picture of your fuse list (from fuse box next to drivers right knee).
The engine bay fuse box should be self explanatory, as the fuse description and outlay is on top of the fuse cover. If this is not the case on your Stagea I'll take a photo and post it up.
However, some Stageas do not have a fuse description list for the fuses under the dash - so if you've got the list, please add photos, and or an explanation for what fuse controls what functions!!
Just trying to help others out (and myself - need to determine which fuses under the dash do what).......
Brendan
https://www.sau.com.au/forums/topic/90854-stagea-fuses-fuse-box/
  • Replies 45
Posted Images
The description is on the back of the coin box that you pull out to access the fuses.
I had it on mine, but then i hacked the coin box up to fit my turbo timer into it, and now i can't read some of them and the box isn't very easy to get out. i didn't really think about the job very well
Thats the thing - mine aint there!! My box has always been 'blank' since I got the car. Now Ive got my EBC in there - but my coin box is very easy to get out, just pull up with some force and it comes out of its slot aok.
I know thats the place for them - so ppls, if you've still got the fuse description in your coin box, can you take a photo and post it up please?
Cheers to you all in advance - and remeber, this is for the betterment of all Stagea owners, being the legends that we are..... (add big backslap etc)
You guys are legends!!!
I went thru the fuses last night (had to get down on my knees, albeit whats left of them, which is a very painful thing for me to do), and found that these fuses under the dash are all ok - as far as my eyes could tell.
I wouldn't trust eyes to see if the fuse is still good, get a multimeter onto them. I've had fuses look ok, i could have sworn by them, but the bit they linked still didn't work. i changed the fuse, voila, working.
Yup, I read that post that you refer to during my searching travels on this forum for leads as to how to fix my 4wd & Abs problem. At this stage working on the engine bay fuse box, and a green 30amp fuse that is constantly blowing.
By the way, I think the fuse in the dash area, that is a red 10amp, very top left hand corner right next to the tweesers in my original photo, is an ABS fuse......
Here ya go fellas
Maybe we can start translating this together and then make stickers up to stick over these? Sure would make it easier for us i reckon! (and the person who owns my stag next)
Translated as best as he could to:
Well done guys, you're all legends.
This is the kind of thing that makes this forum work for everyone. Hopefully everyone with Stageas can print the translation out and keep it with your manuals etc.
Cheers again to you all. Brendan
Edited by bwilkeson
Ive changed the excel download.
Need to note the following:
The very first 'blank' part is actually: Electronic Accessories
The one named earth is wrong it is actually: Clock
Hope that helps
Brendan
Stagea_FuseBox.doc
Edited by bwilkeson
Awesome work Gents,
I blew my interior light fuse the other night, and then when I found the fuse box (with the help of these forums), I was stoked.
Then I saw that the writing was all in Japanese ;)
...but! Isn't the internet (and especially these forums) wonderful to us!?!?!?
Cheers,
Nick T.
  • 1 year later...
Thanks a whole lot for this guys.
I found out today that my right rear light was out. So I took out my coin box but oddly enough the japanese was printed horizontally, whereas on that picture its verticle. So to find the fuse I had to compare its japanese to the japanese on the above coinbox >_< but finally found the right fuse and now the new project is taking the rear lights off. I took out some screws and the result is a wobbly tail light. I think if I pull it out, it might break something (heard a straining sound) so off the stagea is tomorrow to the auto electrician.
Thanks for all the help guys I really appreciate it.
And a sketchy camera phone pic for anybody thats interested.
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
