  • 2 months later...
  • Replies 45
Posted Images
  • 6 months later...
U blokes are ledgends i also had the pleasure of destroying my coin box for a turbo timer... im looking at the fuse listing goin... ah its all in Japanese anyway *GRIND NOISE*... >_<
Thanks a bunch
  • 10 months later...
  lachlanw said:
can anyone elaborate on what "electronic accesiories" is ? like anyone had it blow and been linked to something not working? just wondering aye
Yep, on series 2 auto at least, bottom-right "electronic parts" fuse runs the central locking & I think the key remote receiver. It blew when I shorted one of the central locking power connections when I was installing my alarm/immobiliser. Twice.
  • 3 months later...
Hey guys, first post, not even sure if i'm doing this right!!! Anyway, just recently bought an m35 250t rx four in white pearl. So far im loving it. Just a question to see if anyone knows where the headlights and/or driving lights fuses are located? My driving lights were working when i picked the car up but now theyre not. Thought id start with the fuses. :D
you mean the yellow foggies in teh front bar? I think they are disabled as part of compliance, but you said it worked when you picked the car up?
  dozzer said:
Hey guys, first post, not even sure if i'm doing this right!!! Anyway, just recently bought an m35 250t rx four in white pearl. So far im loving it. Just a question to see if anyone knows where the headlights and/or driving lights fuses are located? My driving lights were working when i picked the car up but now theyre not. Thought id start with the fuses. :wave:
  • 2 months later...
  • 4 months later...
You are all ruining my thoughts. And I love you for doing it.
I have a sticker on the coinbox, with a different setup. I tried to pull the 4wd fuse after i've read i can do it for a short time, but nothing happened. I wondered if i had got it wrong and it wasn't posible, but i must have a sticker for some other car...
Thank you so much for sharing all the information in this forum. :D
  kidafa said:
DONT PULL THE 4WD FUSE and drive mate!!!
It will fry clutch parks after short period of time!
Okey? :banana:
What i've found when e read about it it was good for short drives, but not a day at the dyno.
I thrust you in the same time i get curiuos how nissan could build a car that destroys the clutch if i fuse breaks.
But i will take your advice and not pull it out. :P
  • 2 years later...
  • 2 years later...
  On 02/12/2008 at 11:47 PM, chook said:
posted before but here it is again, S2 fuse box translation.
I know this is an old post, but I've just had the lights behind my speedo, tacho, and dials in the central column go dark in my s2 stagea (ie the cluster lights).. Not so good when you are driving at night as it makes seeing your speed dificult..
Looking at the fuse translations I checked 'meter', 'electrical parts' x 2, and room lamp (just in case) and they were all fine (pulled them out and checked with the meter..) - does anyone have any idea what other fuse I should check or any other thoughts on what the problem might be??
Ian
Edited by ian
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
