Hi guys,
I'm just about to put a full 3in exhaust on my r33 gtst. I have been looking around and have come across two different types of dump/front pipes, one is just your standerd single dump/front pipe and the other is a twin dump/front pipe. I was just wondering if anyone could tell me what the main performance differances are and what is a better buy?
WEB SITES TO THE dump/front pipe THAT IM THINKING ABOUT PERCHUSING..
http://www.nissansilvia.com/forums/index.p...howtopic=116177
http://www.skylinesaustralia.com/forums/in...showtopic=74022
https://www.sau.com.au/forums/topic/90864-whats-a-better-buy/
the split system works well because it seperates the wastegate from the exhaust wheel gas, therefore you get no or little turbulence. its not really the same if you compare it to extractors, but where the wastegate pipe connects again is important, as if its too early, there will still be turbulence. these split dump/front pipes provide more hp and a better dyno curve over the open/bell mouth dump/front pipes
taken from the thread that you linked :)
apparently from what i understand the further back that the wastegate pipe rejoins the better. i think there is a thread discussing this topic around somewhere if you search.
a lot of people on here will vouch for batmbl's products (myself included), and that split dump looks awesome.
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
