Hey guys, i own a R33 GTS-T S2 with a quictrak alarm in it. The problem is i drove it to work and when i went to arm the alarm it wouldnt arm so i just key locked it. This sarvo i got in tried to start it and it would try to kick over but wouldnt go? Popped the bonnet and very faintly icould hear the alarm sounding, so i tried to disarm the alarm but it still did nothing? When i turn the ignition on no system check lights come on in the dash or the main screen on my boost controler dosent appear like it normally does, power windows dont work either etc... but the stereo and lights do? so thats why i think its the immobiliser not battery
Any help / suggestions would be great or even how ot reboot the alarm cheers?
https://www.sau.com.au/forums/topic/90893-immobilser/
where did the car come from? any idea how long the system has been in there? best to get in touch with the original owner on this and have them get in touch with QT. from there they can possibly tell you where everything is.
there's not real reboot procedure on them.
https://www.sau.com.au/forums/topic/90893-immobilser/#findComment-1643959
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
