Thinking of changing the standard exhaust manifold on my R33 gtst. Im making 250rwkw, hoping to get it flowing a little better. What is the nest way to go? i have the following options in my mind:
1) get a stainless steel one off ebay or the like for around $400...(im worried if they are dodgy and will crack and not sure if they are tuned lenght)??
2) liverpool exhausts quoted me $1200 to get one custom done + fitted then ill HPC coat it.. thats tuned length..
3) HKS one or the like,
by the way this is for a low mount turbo in stock position...
https://www.sau.com.au/forums/topic/90899-extractorsmanifold/
hey croat,
stay away from the cheap ebay/chinacopy stuff. you will have way to many problems with it not fitting correctly and the very high possable of it cracking in the near future.
option 2/3 are you best bet. if you can find something like a low-mount cast-iron HKS manifold, buy it as its one of the best lowmount manifold around for an rb20/25 (only problem is that it is to suit an ext gate)
$1200 is alot of money, and im guesing you could get a hks/trust/apexi one for around the same price but mostly it will be high-mount and to suit an ext gate.
Ask the exhuast shop how much for the manifold, without fitting as it is a very easy job, and im sure you could pull it off yourself (if u got the tools and abit of time) which may save you a few dollars.
Good luck and just remember you get what you pay for so stay away from the cheap crap :blink:
hope that helps
cheers mikey :)
We are up to 265 rwkw with the standard exhaust manifold on the R34GTT. If you are looking for less than 300 rwkw, personally I would have a go at power porting the standard manifold.
Abrasive Flow Enginering at St Marys did some others that I liked the look of, defiitely worth a try.
:( cheers :(
Maybe also check out this guy out, cost around the $1000 mark.
I've only heard good things so far, so he must be doing something right.
http://www.calaisturbo.com.au/showthread.php?t=50987
Some pics for those who couldn't be bothered opening up the other thread:
From all reports I believe the 6boost stuff is up there quality wise and probably performance wise with the Jap stuff. But you are better off to get in touch with 6boost himself and make your own mind up.
Unless you are specifically after a brand name and the bragging rights that go with it, I don't see why you wouldn't consider a good local product.
His collector design certainly appear to be unique.
Edited by browny
http://forum.r31skylineclub.com/index.php?topic=27815.15
Have a look halfway down that thread for a pic of the R31GTSR factory manifold.
Might be able to still get it through Nissan and if so should be able to get the factory heatsheild as well for a stock appearance.
Edited by FATGTS-R
too f..ken much!!!!
here is my recent purchase for my build up.. overkill for my goals.. but hell they are sex all over!
i probably paid a bit too much for em .. even with the HPC coat.. but finding them alone.. and for sale was enough.
http://outlawconnection.com/angryaussie/sig/r31/P4030009.jpg
is it an ex GTSr fred gibson motorsport one. apparently..... they flowed the same as the standard manifold.. but in split pulse to help spool up. pretty much the same idea as the GTSR. gains of around 25rwkw was typical, bolt on.
    • Got the gearbox in and the front drive shafts.
    • Hi There I went through a rabbit hole of reading about Xenon headlights and the ADR regulations for having them installed. As people have been defected by running factory xenon I was researching in ways to make them compliant. Everyone always say needs to be self leveling and have washer installed, which I don't necessarily agree with. For this argument I'm using R34 as reference as I'm more aware on the construction of the headlight compared to the R33 Xenon, which may still be the exact same case.   For the self leveling clause taken from ADR 13 - Installation of Lighting and Light Signalling Devices on other than L-Group Vehicles As you can see the bold text "these manually adjustable devices from driver seats" are fine to use. As Series 1 Xenon model headlights do have a 4 level adjuster on the right near the ignition (however not series 2) then these model are consider compliant in that argument.   For the Self Cleaning aspect of this argument clause taken from ADR 13 - Installation of Lighting and Light Signalling Devices on other than L-Group Vehicles Now i can understand the argument that Xenon will need a washer as they are over 2000 lumens, but I clicked on the 12 at the end of that sentence and it takes me to the end notes which states R34 for headlight lenses are plastic, not sure if PL is mark as I don't currently have my skyline to confirm that marking is there. But could you not technically get a lenses with the PL marking on it and then get away with the argument that you need a washer. I went through a quick read of the adr and might have missed something else that may cause them to be non-complaint.    But wouldn't these technically be complaint headlights   Would love to hear other people input on this and shed some light   Edit In regard to the the washer portion I might be mistaken ADR 45 (which I believe is Regulation NO.45) states 12 cd (candela) I dont understand that portion in regarding to calculating the candela if anyone can shed some light. Otherwise I guess throw in a washer for the headlight and you definitely comply.
    • Took it to all Japan day, flogged the hell out of it and took it all, am a very very happy man  don’t know how that ended up in Greg’s thread before
    • Hey Nismo, any chance in the world you still have these seats?
    • I'd say closer to OG GTX3582R, just smaller trim - so 59mm inducer/82mm exducer as opposed to 62/82 for the first gen GTX3582R. Yeah EFRs were boss, the EFR8474 is still an absolute beast and it perplexes me that people still go to things like Turbosmart/Garrett etc when the results people are getting with those are pretty unremarkable compared to what you could get with a turbo available well before those options came out.  DriftSquid (I think) "upgraded" from an EFR9174 to a Turbosmart turbo and promised a comparison video - and kinda shuffled awkwardly and did a bit of diversion from the fact that they didn't get any improvement going to the currently massively hyped brand of turbo from a turbo that was a bit of a frankenstein that had been well superceded in it's own range before the Turbosmart unit he put on there even came out. I suspect the EFR would outperform most Xonas for what a lot of less-insane RB owners would go for, in the 400-600kw range but the Xonas are looking hard to beat up to maybe in the mid 700kw range at this stage- basically where EFRs don't really reach, and before the Precision turbos take over.  What the Xonas do well in the "EFR range" is be easier to package etc, and work very well if a divided housing doesn't suit your application.
