Thinking of changing the standard exhaust manifold on my R33 gtst. Im making 250rwkw, hoping to get it flowing a little better. What is the nest way to go? i have the following options in my mind:
1) get a stainless steel one off ebay or the like for around $400...(im worried if they are dodgy and will crack and not sure if they are tuned lenght)??
2) liverpool exhausts quoted me $1200 to get one custom done + fitted then ill HPC coat it.. thats tuned length..
3) HKS one or the like,
by the way this is for a low mount turbo in stock position...
https://www.sau.com.au/forums/topic/90899-extractorsmanifold/
hey croat,
stay away from the cheap ebay/chinacopy stuff. you will have way to many problems with it not fitting correctly and the very high possable of it cracking in the near future.
option 2/3 are you best bet. if you can find something like a low-mount cast-iron HKS manifold, buy it as its one of the best lowmount manifold around for an rb20/25 (only problem is that it is to suit an ext gate)
$1200 is alot of money, and im guesing you could get a hks/trust/apexi one for around the same price but mostly it will be high-mount and to suit an ext gate.
Ask the exhuast shop how much for the manifold, without fitting as it is a very easy job, and im sure you could pull it off yourself (if u got the tools and abit of time) which may save you a few dollars.
Good luck and just remember you get what you pay for so stay away from the cheap crap :blink:
hope that helps
cheers mikey :)
We are up to 265 rwkw with the standard exhaust manifold on the R34GTT. If you are looking for less than 300 rwkw, personally I would have a go at power porting the standard manifold.
Abrasive Flow Enginering at St Marys did some others that I liked the look of, defiitely worth a try.
:( cheers :(
Maybe also check out this guy out, cost around the $1000 mark.
I've only heard good things so far, so he must be doing something right.
http://www.calaisturbo.com.au/showthread.php?t=50987
Some pics for those who couldn't be bothered opening up the other thread:
From all reports I believe the 6boost stuff is up there quality wise and probably performance wise with the Jap stuff. But you are better off to get in touch with 6boost himself and make your own mind up.
Unless you are specifically after a brand name and the bragging rights that go with it, I don't see why you wouldn't consider a good local product.
His collector design certainly appear to be unique.
Edited by browny
http://forum.r31skylineclub.com/index.php?topic=27815.15
Have a look halfway down that thread for a pic of the R31GTSR factory manifold.
Might be able to still get it through Nissan and if so should be able to get the factory heatsheild as well for a stock appearance.
Edited by FATGTS-R
too f..ken much!!!!
here is my recent purchase for my build up.. overkill for my goals.. but hell they are sex all over!
i probably paid a bit too much for em .. even with the HPC coat.. but finding them alone.. and for sale was enough.
http://outlawconnection.com/angryaussie/sig/r31/P4030009.jpg
is it an ex GTSr fred gibson motorsport one. apparently..... they flowed the same as the standard manifold.. but in split pulse to help spool up. pretty much the same idea as the GTSR. gains of around 25rwkw was typical, bolt on.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
