I got a new Stereo Installed yesterday, too lazy to do it myself and have only just noticed that the drivers side mirror does not fold in. There isn't even any noise coming from it when i flick the switch for it :D
Could the guy who did the install have stuffed something up, the left mirror still folds in ok, there isn't seperate fuses for each mirror is there?
anyone had a similar experience, i had a similar prob in my silvia but it still folded in and made noise
Please help
Kris
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/
Sorry mate, no help from me. i had the same problem as well. not sure what the drama is. i checked the fuses and nothing seems to be wrong. my mirrors dont work at all mate. nothing i gotta move it manually
i will keep watching this thread so maybe someone can help us hey
if i come across an answer i will pm you
lata
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-135750
Take it back to em and say " What the F#ck is goin on with this you bunch of C#nts!!!"
Usually gets the point across. I got my stereo installed ans when I got it back the lights on my climate control didn't work. There sometimes pretty rough.
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-135836
Did they fit new speakers in the door? Sounds like they simply (accidentally) pulled the connector from the switch (I'm guessing the switch is on the door). But, yeah, suggest you get them to fix it.
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-136025
yup, i'd open the door and check for loose connections if u have speakers installed. When i installed my face unit no similiar problems - i don't think the connection is even on that same circuit. Otherwise check fuses - don't forget there are some fuses in the boot as well and engine bay as well.
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-136066
yeah i had a similar problem ... there is a plug which connects directly from the controls ... check if that is connected ... and then check the wiring all the way through ... u should find that its probably either not plugged in properly ... unlikely if one mirror is working ... or there is a loose connection somewhere ... but i'd take it back and make them do it ... so u get your moneys worth!!
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-136119
Only the head unit was installed, it cost me heaps and cause i couldn't bring the price down they offered to install it for me, so i accepted, they came to my work during the day and did it.
It's weird cause i have removed and installed the stereo three times in my car prior to getting a"professional" job done and i have never had any problems, even when pulling the door trims off etc.. all he had to do was install the headunit so i don't know whats happened. It's only one fuse for the mirrors right?
He said he did skylines in the past, anyway i will give them a call today and let you's know, by the way the headunit is wicked it plays Mp3's and WMA, well worth it!
Thanks
Kris
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-136165
oh - stupid me..i remember now... pull off the gearstick surround (clips)... remove dash assembly and its on that. They prolly just forgot to reconnect the mirror plug to the switch when they pulled it out. If it still doesn't work, wiggle it a bit and see whether it works. Alternatively may need to be resoldered if they jammed it on something accidentally.
btw: yes mp3 units rock!
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-136427
I have a similar problem, but in my case the passenger side doesnt fold in - drivers side does!
Unless they are seperatly fused then I am guessing its a wiring issue. When I test drove the car i noticed a funny electrical buzzing on the passenger side and i said that needs to get fixed. I picked up the car and as there was no noise I thought it was fixed. Until I tried to fold the mirrors in of course.
BTW, both of mine are electrically adjustable [up/down/left/right] but only drivers mirror folds in! I will be getting the seller to fix this.
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-136470
yeah i will try this tonight, whenever i pulled my dash apart, i never took any of the connections for the mirrors, etc.. off, i guess the guy installing it did,
Thanks all for your help.
Also don't you hate it when you park your skyline out the front and the 17 inch low profile tyre of your car gets slashed for no aparrant reason whatsoever ($250 out of pocket)and all the other cars out the front don't get touched :hellpisd:
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-136589
I called the car stereo place and they said it's my word against theirs basically and that it couldn't be their fault, they said bring my car in so i suggested saturday, they then go you will need to drop it off because customers can't hang around. Thats bullshit, i don't think i will ever go there again, by the way if anyone wants a hint of who it is it is a place in Balcatta off Erindale road, don't want to bag businesses. I have spent heaps there in the past 2 years and this is how they treat me!.
Anyway I pulled my dash apart, and had a look, first thing the cigarette lighter was not connected, i then had a look at the connection on the switch for the folding of the mirror. It was fine and plugged in. I followed the two wires, yellow and blue down past the fuse box and in to a small black box. Off of this box was two wires, a yellow and a red, with fuse holders (old type 5 Amp) I removed both of these and checked them, they were ok, then I Flicked the switch with the fuses out, the left mirror still folded but the little black box made a funny noise, like it was struggling. I put both fuses back and then tried it, it made it's little switching sound but was fine and again only the left mirror folded.
I jiggled the wires and tried it, it didn't make any difference, the drivers side mirror still didn't fold in. I then took off the door panel and traced where the wires go, everything looked ok (it shouldn't have been out of place cause the door was not touched). I honestly don't know why, the last thing i will try on the weekend is unscrew the actual mirror and put a multimeter on the motors connections to determine whether it is the motor burnt out or the wiring.
All the fuses throughout the car are fine as well the wiring upon visual inspection, i didn't think that it would be the switch anyway cause if it was you would think both mirror would not work. Also the Drivers side left right up and down still works.
Well i don't know it's got me but i'm determined to find it!!
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-137071
Sounds like you've checked it pretty thoroughly and like u say everything seems fine.
Sometimes the switch can be dual side thing. I had a problem on my old car with one headlight not working and it was the actual switch causing one not to work - after trying everything else i ended up having to take it to an autoelectrician. So often yes, one side can go when its just a switch problem.
I'd check the mirror motor like you said.
Final step is just to take it to an autoelec and see whether they can solve the problem (they'll prolly charge $200 or so). Not cheap but if it is important for you to get it fixed, maybe worth it if u have tried everything you can think of.
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-137234
Originally posted by skyliner33wa
I called the car stereo place and they said it's my word against theirs basically and that it couldn't be their fault.........
Good luck to you man, but you shouldn't have to go look for it!!! They are supposed to be PROFESSIONALS, but all professionals are farken sh1t kickers!!!!!
I don't trust ANY so called professional to touch my car, unless I don't have the time, or the tools! If I were you, I would take note of how long it takes you to find the problem. Then rip a quote out of your arse, as any so called professional would, add 20% wank factor to it (again as they would), and you then know what kind of damage you should do to his business. (Smashing windows, walls, etc..) Also leave a note saying: "You should have just fixed the stuff up you made"
(But I am easily angered and don't always think straight when things p1ss me off)
I had a mechanic who is now out of business stuff my car up, then charge me for his stuff up! So I rooted his place of business by writing what I thought of his workshop with used engine oil, all over the ground outside his workshop!
An alternative approach to use, which has ALWAYS worked for my sister (she can be a real bitch), is to walk right into the shop, and say OUT LOAD AND CLEAR, for all customers to hear, exactly what happened, and ask them what they plan to do about it! If they still say it's our word against yours, and that you cant prove it, then ignore that comment, and keep repeating yourself saying the customer is always right, why would I lie about this.. this is unacceptable... I will take legal action (even if you wont, threaten them in a very demanding voice)! PERSISTENCE! Don't stop until you get what you want!!!!! The trick is to be extremely arrogant, rude, LOAD and persistent!
Why my sister even got her insurance company to buy 2 hubcaps, without her even paying excess?!?!?!?! I don't know how she did it, but she did!
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-137239
Walking into the shop and yelling at them could do wonders...do it early morning when customers are in there :rolleyes:
Hmmmm - but in this case, to be honest, it may be nothing to do with them. Often things do go wrong when u take something out. Sure it shouldn't but electricals can be touchy, move something and anybody can end up putting the final nail in a part that is on its way out. Can't always blame a place for something all the time.
But for stereo stuff, i'd spend the effort learning yourself. Not only do you learn how to pull your car apart, you also learn all sorts of stuff in case something goes wrong. Only once did i let somebody install a system in my car, and after that i just thought, **** it, you don't need to be a pro to do this stuff. For small stuff, its worth doing yourself
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-137551
This sounds to me like a bad earth to the mirror relay,
The other place to look is behind the glove box there is a small computer located up there, I have found that if one un-plugs this computer quite alot of things stop working. Such as the 20kph door lock, that beep under the dash, the windows dont go up or down and the mirrors don't work (to name a few) it may be when hunting for power or whatever they chopped a wire to this computer.
Regards
Damqik
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-137947
i just took the door panel off, put a multimeter to the two wires that control the motor, with the ignition in the on position and got a reading when in the outward position of approx 12 volts. I switched the switch to the inward position and got a reading of approx -12 volts. I think the motor has had it, will double check this, but if it is i might as well get a whole new mirror :(
Anyone know in WA where i could find one?
Just tried the mirror on the left hand side and it didn't work, so this confirms it to be the motor in the mirror, :uh-huh: at least i know now. I'm not to sure if it was the car stereo places fault this might all be a coincidence
Kris
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-138562
If this is the case then it may be the contacts in the mirror then, as power is put to the mirror the mirror folds out or in, when it gets to the end of its travel the switch contacts get opened.
Have you yet pulled the mirror apart? there is also a heater in there to melt ice tho this may of been one of those skyline options so the heater may not be on all models,
I cant see any reason why you couldnt take the mirror apart and clean the contacts as I feel it is unlikely that the mirror folding motor is burnt out.
My passanger mirror somtimes sticks open but if I give it a tap it then folds. tho before the tap the motor wasn't even trying to move.
see how ya go with it.
Regards Damqik
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-138670
check the white plug that connects the wires from the door to the main body. I mean the one which the grommet runs into. You have to unscrew it. They would have put the new stereo wires through there and may have accidently wrecked another wire in the process.
sorry if this has already been suggested, i haven't read the rest of the thread....
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-138971
Dude, check the resistance of the motor with your multimeter. If it's open circuit, then the motor's definitely had it. You might want to take the motor apart and have a look though if that is practical. If the coils are not burnt (again, verify with multimeter), you may be able to restore it with a little cleaning and greasing.
https://www.sau.com.au/forums/topic/9091-mirror-folding-in/#findComment-139545
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
