The New Mx5
Just had a ride in my friend's new MX5..........damn the car feels powerful with good power to weight ratio........
Now I feel my skyline doesn't have enuf power (which it doesn't)........so unsatified with my current power............im gonna be in a slump for a while
Engine type 2.0 litre in-line 4 cylinder 16 valve DOHC S-VT
Engine capacity cc 1,998
Bore and stroke mm 87.5 x 83.1
Compression ratio 10.8 : 1
Maximum power kW 118 @ 6,700rpm
Maximum torque Nm 188 @ 5,000rpm
Throttle control Electronic (drive-by-wire)
Fuel system Electronic fuel injection
Fuel tank capacity litres 50
Fuel consumption man (combined) 1 l/100km 8.5
auto (combined) 2 l/100km 8.8
Recommended fuel Premium unleaded (min. 95 RON )
Yeah the MX-5's are a great drivers car. Its a shame they can be underrated as a performance car as you'd only rarely see a nicely modded up one as you would pretty much see them in the hands of some toorak or south yarra dude who only bought it because it was a convertible and has kept it stock standard for the past 10 years being blind to further modding.
Comparing it to my R32 GTSt I've driven both the NA and NB series MX-5's they are piss weak but they feel alot more chuckable around corners even though they are relatively underpowered. they'd be a really good slightly most costly alternative to an AE86 if you looking for a light NA rear-wheel drive car.
they aren't as fast in a straight line (but then again I'm not into drags at the traffic lights, no skill in that.) but they are awesome on the twistys. :)
they'd be a good drift weapon if given a good balanced setup.
not sure about the specs, but apparents she had the limited edition of the MX5, bilstein suspension...... I think its about 160 hp and 1100kg......AND
7 thats right 7 CUP HOLDERS!!!!!!!!!!!!!!!!! and I could seriously use one in my car.
Anyone see the ad in drive for the new mazda 6?? 190kw and 380nm torque at 3000rpm wwttff thats nuts how can they get that amount of torque at such low revs?
Modern turbo cars are getting better and better at producing massive torque at low RPM. The old school of turbos were laggy and needed revs revs revs to make power, while the NAs made the low RPM torque. Now the opposite is true, with high powered NAs needing RPM to make big numbers, and turbo cars making huge torque at very low RPM.
Some of the more rediculous torque figures are from small modern turbo engines:
Holden Astra Turbo: 250Nm @ 1950RPM from 2.0 litre 4 cyl
Volkswagen Golf GTi: 280Nm @ 1800RPM from 2.0 litre 4 cyl
Saab 9-5 Aero: 350Nm @ 1900RPM from 2.3 litre 4cyl
And just to make them all feel weak:
Bentley Continental GT: 650Nm at 1600rpm
Mercedes SL65 AMG: 1000Nm at 2000-4000rpm from 6 litre V12
Bugatti Veyron: 1250Nm at 2200-5500rpm from 8 litre W16
The 4 banger creates max power at 5500 so it probably redlines about 6, so max torque would be around that area.
Power is dependent on both revs AND torque, so peak power does not necessarily appear near peak torque.
why oh why doesn't Mazda put a rotary in one damnit!
This was for sale a few months back:
13B Rotary MX-5
Alternatively check out the Bullet Roadster. Basically an MX-5 with a 13B, 20B,Lexus V8 or supercharged V8. Bit more expensive than the standard MX-5 though! Mazda will never make a rotary MX-5 because it will eat into RX-8 sales, and perhaps the rumoured upcoming RX-7.
I have a reasonably modified 1989 NA6CE MX-5 (imported Eunos Roadster actually), as well as a newly complied and registered R32 GTR with HKS GT2530's and supporting mods.
The MX-5 is much fun it's criminal. Different sort of fun tho - and I'd actually take the MX-5 for hills driving.
The GTR is just insanely powerful and efficient, but the MX-5 is supremely fun to drive. I think my next car will be the new MX-5, modified of course :O
 Share
    • Thanks to @V35_Paul there is an oem stereo available on gumtree, but the fascia is slightly different. It has a flip up screen as opposed to my pop up screen. Am I able to disconnect the radio/cd player from the fascia to use it on mine?
    • Had to google what a quart is lol.. so rough as guts a litre. That's a bit excessive, also what oil weight are you running? The whole steam cleaning idea isn't too far fetched either. Maybe as you suggested, turn off the WMI (assuming your Kebabtech pulls timing, boost, etc.) and run it for a bit and see if there are any noticeable changes in spark plug colouring.
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
