No. sorry to say Vortex 95 and 98 are not rich in Toluene.Toluene is a solvent . Different refineries use different processes to increase RON . I make the stuff at kurnell. Also the Companies have agreements in different states about supply. There is no Caltex refinery in Victoria. You will probably find that is a Shell product.
All petrol has some amount of Toluene in it though. What do you mean by 'solvent'?
What are the aromatics in Vortex 98 then? What does Caltex use to raise the Ocatne to 98?
Shell optimax does not have its RON increased. It starts at more than 98 RON and is cut.
  • Replies 62
Posted Images
Catalytic reforming units are used to increase the octane of HSR to bring it up to a RON of 95-102. Petrol from the bowser is usually a mix of different unit rundowns that are blended to and tested to be sold.Toluene is not added to increase RON. Toluene, Benzene, Propane, Butane, Xylene, Cyclohexanes, etc are all products of the Reaction in our Reactors. Heat is used to increase the reaction that gives a higher RON.Shell talks about density of Optimax. The density of our rundowns are usually quite a bit higher . This is one of the specs we run to.
HSR is what is distilled from crude oil. There is usually about 4-6 different types of crude running through a crude unit at any time. We use about 10 differing crudes. This is due to availability , and specs needed for summer or winter fuel , Diesel , jet fuel, heating oil , feed to other units, base stock for lube oils and bitumen. Caltex haven't used added octane inprovers since Tetraethyl lead was removed some years ago. We do add a cleaner that cleans fuel systems.
MOst of the Benzene will be removed from all gasoline on the 1st January 2006. This is a Government regulation.If you got BP hi octane fuel in WA it came from BP"s refinery in Kwinnana. If you got Optimax or Synergy or Vortex it came from that same refinery.Sometimes we will send fuel to Victoria to meet a need of the refiners down there and if we have supply probs they will ship it up to Sydney. There aren't tankers runningaround the coast with finished product to stock all the different brands. Kurnell supplies 2/3 of NSW petrol needs so it would be difficult to send any to other states as well.Hope this helps Sorry MIK I misunderstood the tolune part. thought people thought it was an additive. Toluene is used as a solvent in producing lube oils in some processes
That was a great read.....
Was waiting for someone to do a proper test....
Didnt have my mone on caltex tho.... I assumed Optimax was a touch better....
My own tests....
Caltex 98 - Car pinged its tits off (thought i must have got regular unleaded)
BP Ultimate - Car ran great 270km per tank (air fuel ratios were good)
Shell 98 Optimax - Car ran a little rough 300km per tank (air fuel ratios were bordering un safe)
So i generally use Ultimate or Optimax. I find when using Ultimate my bumper is heaps dirtier after a tank and believe this is due to Optimax being a little cleaner.... Also i drive my car the same all the time.... Average fuel consumption is the same every time.... 300 per optimax and 270 from ultimate.... Plus i can get 4cents off at shell.... So i try to get shell as often as possible... However im empty today so im gonna fill on Caltex 98 and try again.... Maby i just got a bum batch the first time????
Using Sydney as an example, am I right in assuming that all 98RON fuel sold here by BP and Mobil is either Optimax (from Clyde) or Vortex (from Kurnell) since neither BP or Mobil have refineries here?
If that is correct, do BP or Mobil (using Sydney as an example again) add their own additives to the fuel refined at Clyde or Kurnell to get their own unique fuel mixture which they then brand as Ultimate or Synergy 8000 respectively?
If they don't add their own additives, then I'm confused as to how there can be differing result between each of the fuels as essentially they should be one of two variants available (given that the tests were conducted in Sydney).
Hopefully someone in the know can answer these questions...it would be interesting to know what really happens.
Might also stop me going out of my way to buy a particular fuel :O
Case and point.... refer pic....
After one tank of ultimate....
going off your fuel consumption and how dirty your rear bar is either you have a massive amount of power or your car is running way to rich... i guess its hard for me to see if my rear bar is very dirty being black and all but i dont seem to get much/if any crap on my rear bar and i only use ultimate.
How can you do a test with a select batch of fuel.
How about the sample the fuel from 100 different servos around Aust and make a comparison.
Look for consistancy in the performance of the fuels as well.
Ill be sticking with the BP Ultimate myself.
Thanks for the info kimbod its great :(
I'm also interested in ECR033's question....do we only have 2 identical products in NSW or are they modified by each supplier either at the refinery or afterwards?
Shell Clyde would make Optimax in NSW. I have heard good things about BP's hi octane ,the same as most people have heard about the problems optimax caused in older cars. Each refinery have different plants that are used to make their fuel. We have different units to Shell and to the other companies, Since the companies use different methods to get the legal specs the compostions will obviously be slightly different. During the Ford Sierra days Shell would make special blends for DJ. we made a special one for Colin Bonds Alfa.
Talking about fuels...toluene was used in f1 cars in the 80s at 85 percent. It was very sucessful and these cars were making here hp per liter. Just wandering if anyone could pm me where to get toluene...??
Cheers
Not sure if anybody would be allowed to buy it. Companies can of course. During the Turbo days Ferrari's fuel supplier[i think ELF] would add an amount of water to the fuel . They had little mixers in the tank to keep it in suspension This helped with keeping the engine alive . Little motors with BIG horsepower. If my old senile mind is right BMW"s 4 cylinder would have a qualifing BHP of around 1500-1700hp
Tolulene is the most common ingredient in octane booster and can be purchased as High aromatic thinners. you need to make sure it is 100% tolulene. it comes from paint stores. A mixture of 10% tolulene in 98 RON is acceptible. it also increases the MON ratin of the fuel.
Water can also be added to fuel however in a high enough density it has the ability to hydrolock an engine. a better way to do it is thru injection into the intake before the throttle body :(
Pretty much. Many years ago (OK, not that many) I worked at Clyde Refinery, and there was a single 6 inch pipe that went across the river to BP's facility in Silverwater.
Ahh ... here's where things get tricky, because one side is certainly not going to tell the other what they do :(
There could be a few explanations. The fuel samples mentioned in the report say they drew the fuel from the bowser. Now, the fuel in the storage tank at the servo is going to be a mix of different batches of fuel, *potentially* from different sources. (ie: Singapore exports a fair amount of fuel to Australia). But, since the sources were mentioned in the report, then this needs to be accounted for.
Unless fuel samples were taken from all over Australia at many different times, the results of the tests are bullshit and don’t hold much more validity then a debate on the internet.
Not really, a report is only as accurate as the data, and as long as this fact is mentioned in the report, then it is valid for the samples under test only.
hmmm interesting results..
it's good that someone had a go at this age-old question, but i'm not convinced
Having meself been in medical research, its very hard to just do something and have everyone believe it. you have to prove it to them and remove ANY variable to show that the SINGLE factor that changed results was the factor in question. This is always going to be very hard with this kind of test
My quarms are that:
- tests were not repeated
- use of only one engine type (forced induction only)
- use of a modified car rather than stock car with stock ECU
- where did they get thir fuel from? local petrol station vs. directly from the supplier --> they could have measured the octane rating themselves to get the exact octane rating of the fuel they used rather than go by the advertised octane
my conclusion:
it was a fine "experiment", but was not conclusive enough to base anything solid on
just my 2c
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
