That was a great read.....
Was waiting for someone to do a proper test....
Didnt have my mone on caltex tho.... I assumed Optimax was a touch better....
My own tests....
Caltex 98 - Car pinged its tits off (thought i must have got regular unleaded)
BP Ultimate - Car ran great 270km per tank (air fuel ratios were good)
Shell 98 Optimax - Car ran a little rough 300km per tank (air fuel ratios were bordering un safe)
So i generally use Ultimate or Optimax. I find when using Ultimate my bumper is heaps dirtier after a tank and believe this is due to Optimax being a little cleaner.... Also i drive my car the same all the time.... Average fuel consumption is the same every time.... 300 per optimax and 270 from ultimate.... Plus i can get 4cents off at shell.... So i try to get shell as often as possible... However im empty today so im gonna fill on Caltex 98 and try again.... Maby i just got a bum batch the first time????
Could be a bad batch, when Vortex98 first came out we had a car towed into work with half a tank of water after filling up on it.
  • Replies 62
Posted Images
I guess this shows that fuel from differing companies do vary. The government says what the RON should be and there is a plus or minus fiddle factor. Also winter fuel has a higher RVP or DYPE to make your car easier to start. Of course in summer this is reduced so you don't have problems on hot days.Though govt regs are lowering these to cut back on the smog levels.
As you can see in the states of Australia the fuel will differ because of which refinery made it.
The other thing to remember that denser fuels tend to make you car run a bit richer.
The higher the RON or MON the higher it's resistance to knocking. Hi octane fuel in a car that doesn't have the sensors that our skylines have[ knock sensors, etc] will have no increase in performance .
I guess the water problem is one of those things that happens. service station tanks get condensation in them,etc.I won't use Mobil 1 oil because i bought a 5 litre container from Big w a few years ago and luckily I notice it had a lot of water in it. I rang the Mobil help line . They couldn't explain it.
I allways found that vortex 98 pinged my skyline very hard but as soon as i put Ulimate in it the pinging went away and the car went harder. I also found that Synergy 8000 SOMETIMES would make my car go noticably harder.
weid that Vortex came out on front - i have tried it many times and got the same result every time.
I wonder how much free fuel or how much money Caltex paid MRT ? =)
Interesting that for what seems to be a fairly thorough test (to the extent of getting some folks
with a van from Caltex to analyse the fuels) they didn't:
a) adjust mixtures so that they were exactly the same for all fuels. Given that Optimax
claims to be a denser fuel, I'd have thought this was important.
B) adjust timing to take maximum advantage of all fuels (timing _was_ adjusted, but not for
individual fuels).
If we accept that the results are a) accurate and B) relevant given the sampling procedure
(and there have been some arguments to the contrary earlier in the thread) then the
test shows that Vortex98 is the best bet for 'good power' on an untuned Ecutek in a Subaru.
I don't know that it follows that Vortex98 is necessarily 'the fuel' to use on a tuned car.
My belief is that 'the fuel' to use on a tuned car is the fuel it was tuned on, batch variations
aside.
I'd love to see a comparison where the same car was adjusted for the same
mixtures across a range of fuels, and the adjustments needed shown.
Then I'd like to see the mixture-corrected car adjusted for timing (with the adjustments
tabulated) and see power measured.
Then I'd like to see the tests repeated, monthly, for 12 months.
I'm dreaming :(;)
Regards,
Saliya
something else you might be interested to know
from the Federal Chamber of Automotive Industries website
http://www.fcai.com.au/ethanol.php/2004/03/00000001.html
"Nissan vehicles manufactured from 1 January 2004 onwards are capable of operation on ethanol-blended fuels up to E10 (10% ethanol), providing that blending of the ethanol component to the petroleum component of the fuel has been properly made at the fuel refinery (ie there is no "splash-blending" of the fuel).
For Nissan vehicles manufactured prior to 1 January 2004, Nissan Australia does not recommend the use of E10 because of drivability concerns and/or material compatibility issues."
regards
Jase
im still not clear about whether Ethanol is good for the car.
i remember they put it in a lot of petrols and damages engines.
theres new 'cheaper' petrol with ethanol (<10%) 98 otcane..
i just want to know, is this stuff any good??? or should i stay away.
if i could afford ultimate, i woudnt ask these questions...
The main concern with Ethanol is it's a solvent and can eat some types of fuel lines, but mate you drive a performance car, one that was designed to have a diet of Japanese super (100RON), tighten your belt and buy 98RON, buying lower octane fuel will only cost you a LOT more if you do engine damage because of it.
Siliya has hit the nail on the head. What happens when you lean out your mixtures? You get more power. All these fuels test to be similar RON, so advance sould be similar. The results that we are seeing is how close to the fuel that the ECU was tuned with, (which was vortex).
Overall I think the quality of the report is pretty poor. It looks to me like it's a draft that hasn't yet been scrutinised by the academics that should have been overseeing the testing.
eg
But why were they better? After consulta
Winter mix March 16th to November 14th maximum legislated amount is 90Kpa @40 deg C ?????????????????????
PAUL CHECK HERE.
Please refer Appendices and chart XXXX before reading this part!
If I was UNSW i'd be dissapointed that something like this was released. If I was MRT and they were asked to pay for this I'd be suitably unimpressed as well.
I'd even go further than what Siliya suggests and include ADR drive cycle testing.
eg
If you go through the OCAU thread, u can see that this reports is actually an unfinished draft that was leaked.
I've heard some dyno operators in SA are recommending the ethanol blends for maximum power, but cars must be tuned to suit the fuel. Don't know how accurate these rumours are, so treat them with a grain of salt.
I don't think I'm game to try anything else unless I know for sure it won't affect longevity in my car. Ultimate is consistent for me, the cleanest of the lot, and I have enough power as it is at the moment :)
I wonder where SA gets its fuel from and which would be the most "fresh" fuel. Anybody know?
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
