Alright ... newbie coming in, some one plz tell me who lives round Sydenys South West ... like Quakers Hill Castle Hill Places like that ... cause if i dont race im gonna go crazy here. If you can put up with a noob for awhile i promise i want bug u too much. :)
Edited by ^De_LiL_Devil^
https://www.sau.com.au/forums/topic/90954-sydney-south-west/
isnt' castle hill east? like near coogee?
LOL..
castle hill is like up northwest.. relative to me..
liverpool is west..
dont be silly and request that you want to race.. as someone has said leave it for the tracks or drags..
what car do you drive?
Skyline GT-R34 ... well sometimes ... im not suppose to but it dont stop me, im allowed to once im off P's ... lol ... Eastern Creek is West way west ... castle hill is north ... not quite as west as me ... try quakers hill or furhter
castle hill is north west man.............and don't be an idiot.........if you wanna race, go to  the race track
I was racing at 14 in america .. like im gonna change now .. only prob is i didnt have a liscence then and now i have to wait three years to drive MY car not my parents ..
Edit: for all those who read the 'i wa drivin at 14 in america' .. its was my besty, Jes, she gave me this site so i use it now not her ... My names Felcity and i've not been drivin long ... jst round carparks and that til i get my lisence on friday 28/10/05 ... Jes was the racer since she was 14 ..
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
