  • Replies 42
Yeah Bank cheque, i second that and cash it asap
You need your rego papers. On the back there should be a car disposal notice thing, its a form.
Fill it out and sign it and get the buyer to sign it too. If you want to be nice, you can put down a lower sale price on the form so the buyer will pay a lower transfer tax when he transfers the registration to his name (I think its 3% of agreed sale price).
A bank cheque is bought with available funds. As long as you cash it your not going to run into a drama of it bouncing, it can't.
Write up a sales reciept and include.
* Make
* Model
* Year
* Rego No
* Engine No
* Chassis No
* Sale price
* Agreement of sale (paid by bank cheque, electronic funds transfer)
* Conditions
One for you and a copy for the buyer. Sign and date it.
http://www.vicroads.vic.gov.au/vrne/vrne5n...A256FD300241C01 - transfer papers
print em out and fill them in.
and yeah... bank cheque and a receipt with the info people have already stated
Yeah that's a good one.  "Buyer purschases car as is, where is"
or "Sold as Seen" is another good one that I have used before. Covers your back incase of any nasties.
before tehy epick it up tell teh mto get a cover note to drive the car and before they take it you take of the plates and return them to vic roads n u get refunded whts left on ur rego
you only take the plates off if ur not selling with a RWC or rego
yea bank cheque is always the best to go! there pretty safe!
on the vic roads form, the seller and buyer writes in an agreed value.
its got how much the tax n stuff costs on the form for the cars value
but if the buyer is nice, and wants to save money, and you too i think. just put in a lower 'reasonable' price. otherwise they fine you if you do. so dont get caught
my friend baught a 18,000 dollar land cruiser, and on the form he wrote that it was worth 4,500. saved lots of money :O bit risky tho.
  • 3 months later...
also worth calling up vic roads a week later and confirming the rego has had its change of address done, otherwise you may end up getting fines for the car even though you don't own it anymore
when the transfer papers are processed at vic roads, are the kilometres looked at?
ie I am looking at a few cars, but am kinda suspicious to the amount of k's they have done
Does vic road write down the kilometres on the car when the car changes owner...so that if the clock was wound back it vic roads would pick it up?!!?!?
bigtim, if your sus about the k's on the car your probably right though what can u do about it? nah dont think vicroads would check the k's on the car. It would be too much work and hassle for them. Y would vicroads care about how many k's the car has. Its not like they r buying the cars. But then again i wouldnt know cause ive never sold a car
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
