Got a Apexi ECV for sale people. This is the bolt on version that goes behind your cat for simple installation, not the pipe type where you have to cut your exhaust and weld it on.
Its been used but its in perfect working order, only selling because my cars exhaust noise is pretty quiet now. So you boys out there worried about getting defected for exhaust noise can use this to quiet your exhaust down when you see the boys in blue, and leave it open while driving normally for no restrictions. :)
This is a 3" diameter version guys, the bolt on types for Nissan only come in 67mm which will be a fairly Large restriction if your exhaust and cat are 3", so if you got a 3" cat and 3" catback you can use this without any power loss. :( These are also compatible with the DECS too. :)
Comes with original box, and everything that came with it: ECV, cable, brackets, installation booklet etc. After $250 for it.
PM me call on 0403578014 if interested.
Thanks,
Andy
https://www.sau.com.au/forums/topic/90980-apexi-ecv-3-bolt-on-version/
