mate, your way of doing it is completely different as your car is a gtr with twin turbos and your solenoid pos is different. I got a single turbo with ext gate. Ive wired it up and it seems to be good so far. My problem has been solved. Good to see yours is also wired up and now plumbed up correctly. The ninja booklet provided has the right details and drawings for different setups for plumbing of the solenoid.
Cheers.
I've been having problems with my PFC BCK as well.. I'm not sure if I installed it correctly...
Here's the skinny... r33 SII rb25det in a 95 S14...
There was NO factory boost solenoid on the motor when i recieved it... so i have no female plug for the solenoid to plug into....
The Maps sensor (red,green,black wires) plugged conveniently into the side of my PFC...
I've got the vacuum lines hooked up to the solenoid and plugged the pink/black harness from the solenoid into the brown/red harness that came with the kit
Now here is where it gets messy.... since i had no factory solenoid.... i have no female plug for the red/brown harness (solenoid).....
So from gathering little bits of information the best solution i could come up with was hardwiring the red wire to pin 25 and the brown wire to pin 50 on the efi harness.... (pin 50 ground/pin 25 boost control)
My hand commander reads boost accurately.... since the map sensor is plugged into the side of the PFC.... but I'm not sure if the boost solenoid is even functioning properly...
Any ideas on where to start??????????
-Andrew
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
